Browse Forums Building A New House 1 May 19, 2018 5:28 pm Re: Advice on house plans 4May 20, 2018 11:01 am mummy1 The front porch is facing North You mean the entry? Then I would say unfortunately much of your house is pointing in the wrong direction to make benefit of the Northern aspect, although the Northern end of your living space will get some benefit, and Bedroom 1 and 2 and the Study will be nice spaces to occupy. Advice on house plans 5May 20, 2018 11:23 am Bed2 sharing a wall with media may be a bit noisy - perhaps swap media and study? South facing kitchen and dining will be dark and cold in winter. You could look at clerestory windows or similar to get north light into those areas. Re: Advice on house plans 6May 23, 2018 10:07 am Mummy1 It's a good idea to also put up the location, Owner Builder/Builder, budget, soil types, Prefered construction,etc,etc There are plenty of apps that allow anyone to sketch floor plans, but only one that I know that allows you to design within your budget..Remember the more info you put up the better the reply..hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Advice on house plans 7May 30, 2018 2:18 pm We've been wondering about the same problem. We've been struggling to see our plans lifesized so started a thread viewtopic.php?f=31&t=92263 Re: Advice on house plans 8Jun 10, 2018 11:09 am So this is what the first proper draft looks like. Custom design with a franchise builder in south west NSW. Construction brick with some rendering at the front. House (porch side) is facing directly north. Block is sloping downwards to the road. The views are to the north east so we're trying to capture that also. Block frontage is 31m and there is around 3m fall across the house plan. Soil is class M Require drive through garage to a shed. Any further thoughts please? I'm not liking the master bed directly off the living room so any ideas on how to deal with that would be great. Also, are we trying to fit too many rooms into the space? Thanks a lot! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Advice on house plans 9Jun 10, 2018 1:29 pm mummy1 So this is what the first proper draft looks like. Trying to be helpful and constructive here, but since you made no changes based on previous comments, I wonder if you a completely fixed on your original floor plan. That said, given that the floor plan is really only 50% of the design, perhaps you could post up some the elevations so we can see what design elements have been incorporated to compensate for the poor orientation of the floor plan. Re: Advice on house plans 10Jun 10, 2018 3:39 pm arcadelt mummy1 So this is what the first proper draft looks like. Trying to be helpful and constructive here, but since you made no changes based on previous comments, I wonder if you a completely fixed on your original floor plan. That said, given that the floor plan is really only 50% of the design, perhaps you could post up some the elevations so we can see what design elements have been incorporated to compensate for the poor orientation of the floor plan. No elevations as yet, and no not "completely fixed" on anything. The block is sloping, approx., 6 meters fall from south (high point) to north, over 70 meters. We also need to consider flow to the rear as we have no rear neighbour with a reserve joining our land. Want to advantage of this. Not fans of kitchen at the front of the house. The floor level will probably be 3 meters above street, coming to flat ground at the rear. Really tight at the top of the stairs- how to get furniture into those rooms? Study books - does anyone really use them these days? Large storage closet would be more functional. 2 6895 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18211 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 13781 |
