Browse Forums Building A New House 1 May 13, 2018 7:25 am Hi, We are getting close to our finish date and our house has had a bit of a clean up, we had a chance to get a look at it today now the dirt has been cleaned off, and I was quite shocked at the scrapes on the aluminium window frames, what are people’s thought on these, should we push to get these fixed/ replaced, as l am not happy about these. We also found several damaged floor tiles, plus a serious leak around a big window which has caused the sill to swell. ( first decent rain we have had since our build started) Attached a few images, l am interested in people’s thoughts. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Damaged window frames .... 2May 14, 2018 6:43 am GillyH Hi, We are getting close to our finish date and our house has had a bit of a clean up, we had a chance to get a look at it today now the dirt has been cleaned off, and I was quite shocked at the scrapes on the aluminium window frames, what are people’s thought on these, should we push to get these fixed/ replaced, as l am not happy about these. We also found several damaged floor tiles, plus a serious leak around a big window which has caused the sill to swell. ( first decent rain we have had since our build started) Attached a few images, l am interested in people’s thoughts. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Not looking good. Who is the builder? Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Damaged window frames .... 3May 14, 2018 5:20 pm I am not sure if it is still fixable. Time to replace it now, I think. Re: Damaged window frames .... 4May 14, 2018 6:19 pm It should be in as new condition so should be replaced. Building a Madison 45 with Porter Davis Madison 45 Blog (Send me a PM with your email address to be added) For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 7640 It's hard to comment as the photos area bit dark ( you might need a new 15 - just got one and wow ) Jokes aside, I can see one member that is cracked. I would find a… 2 2197 |
