Smart lock with door handle for entry door
Page 1 of 2
megg,
That's a good idea! What brand are you thinking of going with?
Bunnings sells a great range. Lockwood is awesome.
Hey That's a good idea! What brand are you thinking of going with?
We are in the process of updating our entry door and I would like a keyless door lock with a handle. Does anyone have any suggestions?
Why do you want a handle? I presume you meant a passage handle with a latch.
We’re also looking for a smart lock to replace the existing lock after handover. However we had opted for vertical bar handles on both sides of the doors so we may have some problems fitting any smart lock under the bars as the inside facing part of smart locks are usually quite thick
Can't you offset the lock: above, below or either side of the handle? How would you access the keyhole or keypad under the handle anyway?
Hopefully, the front part is ok but the back part is currently just a simple latch. If we change to a smart lock, the back part is likely to be thicker and harder to use under the bar
Metricon Liberty 45, Ryde NSW
http://forum.homeone.com.au/viewtopic.php?t=82846
Hopefully someone can post up their feedback on doing this
I am looking at either the Gainsborourgh https://www.bunnings.com.au/gainsboroug ... t_p0012718 or the Samsung https://www.bunnings.com.au/gainsboroug ... t_p0012718 or the Lockwood https://www.lockweb.com.au/en/site/lock ... door-lock/
I don't want to have a separate deadbolt lock.
I think the lever action is the easiest to open and close.
Love the look of your door handle arcadelt. We are android users, so Apple software is not something we would use.
Schlage have the exact same lock that is compatible with Android.
There was no link to the Samsung lock. The other two are digital locks, but I would not call them fully "smart" since they have no connection to your phone or the internet, so no remote advice or management. Of course, that might be exactly what you are after.
Most smart locks are deadlocks, so you don’t need a seperate deadlock unless you want the door to be secure from the inside too.
No doubt, lever is easy but not as easy as just pushing the door open.
With your push door, how does the latch engage/disengage?
The door has two roller bolts which hold it into place when it is unlocked. Obviously the smart lock bolt locks it into place when locked.
How does the roller hold up in windy weather? Is there any chance of it blowing open on its own?
Also where do you buy these
Thanks Arcadelt, that’s actually the lock we are thinking of getting (in black)
We have a black one on our laundry door.
Can 1 app control the 2 locks?
You can access both with the Schlage IOS app, just by swiping to move from lock to lock.
Alternatively you can add the locks into Apple HomeKit and control it from there along with your other HomeKit compatible devices, including voice control using Siri.
Also where did you buy your door handle? do they have other types as well?
6
Black on light wood does look good. Not sure if it will be as long lasting as a steel finish?
10/03/2024
I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an…
25/05/2023
1
Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off
