Browse Forums Building A New House 1 May 06, 2018 2:34 pm Cant see why bricks cant go from cat 2 to cat 3, they are quite some time away from being actually needed, price increase could be anything from 100_300 extra Per thousand bricks, its a easy change as stocks from a supplier in which your order would be months away. I engaged my builder in December last year and we’ve been working on preliminary drawings for last couple of months. I got a call from the salesperson this morning… 0 548 yes it is possible but watch for noise transmission, decouple as best you can. Maybe wider top and bottom plates with 70mm studs to allow the cabinet to be recessed fully 1 6636 You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 36960 |
