Browse Forums Building A New House Re: WA - Ben Trager - Hammond Park 21Nov 26, 2018 2:54 pm _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 Re: WA - Ben Trager - Hammond Park 23Dec 14, 2018 11:04 am my new build thread- Ben Trager https://forum.homeone.com.au/viewtopic.php?f=31&t=89826 my switch build thread (2011) https://forum.homeone.com.au/viewtopic.php?f=31&t=36569 Re: WA - Ben Trager - Hammond Park 28Mar 07, 2019 10:11 pm I would be making sure (and not coming from Ben Trager) that the polystyrene cladding isn't on the banned list that has just been released. Banned cladding systems: CM40029 Ozone Panel Building Systems CM40066 Alpolic A2 CM40067 Alpolic FR CM40076 Ultrabond FR CM40079 Vitrabond FR CM40082 Dulux Exsulite TM Kooltherm Façade System CM40093 Larson FR CM40138 Dulux Exsulite TM Thermal Façade non-cavity system CM40162 Cladex FR Re: WA - Ben Trager - Hammond Park 30Mar 08, 2019 1:08 pm The banned list is for Class 2 buildings up ( Multi Density Units & High rise) no doubt it will extend to Class 1 Residential Construction, Also check with your home insurance providers.. premiums are set to skyrocket, should it become non-compliant Goodluck Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: WA - Ben Trager - Hammond Park 32Mar 08, 2019 4:07 pm steel THanks for letting me know guys. I have confirmed that BT does not use any of the banned EPS boards. Yours looks like a basic foam like what most houses uses. They are actually flammable. But not on banned list yet for residential housing. Re: WA - Ben Trager - Hammond Park 34Mar 08, 2019 8:42 pm The only way to stop people speculating when they see a photo/image like that is for Builder to put up the material data that is used up on their website Do you have a link to the Material/Chemical/Engineering properties? Just Curious? Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: WA - Ben Trager - Hammond Park 35Mar 08, 2019 8:49 pm StructuralBIMGuy The only way to stop people speculating when they see a photo/image like that is for Builder to put up the material data that is used up on their website Do you have a link to the Material/Chemical/Engineering properties? Just Curious? But isn't polystyrene itself is flammable right. Not talking about protection from outside. More like if house caught fire inside the poly will burn very fast? Re: WA - Ben Trager - Hammond Park 37Mar 08, 2019 9:39 pm Here Fire polystyrene flammability Smoke fire retardants toxicity Check with a fire engineer and I would refer you to the Eurocodes which are more advanced Than Australian Standards ATM. hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: WA - Ben Trager - Hammond Park 38Mar 09, 2019 8:57 am StructuralBIMGuy Do you have a link to the Material/Chemical/Engineering properties? Just Curious? http://www.builditeco.com.au/wp-content ... ochure.pdf Over the last 3 days, they smashed out the rest of electrical wiring, all piping and the downstairs roof. Suggested lockup at this stage is next month then two more till completion. Had my first meeting with site supervisor and he was a really good bloke and went through a fair bit with me. Re: WA - Ben Trager - Hammond Park 39Mar 09, 2019 10:11 am Thanks for the Installation and Technical Data I'm sure others considering building will research thoroughly what's provided I find it perplexing that builder's don't put up information &/or provide the bare minimum when referencing the NCC. Sorry to hear about the house damage, It doesn't sound like a random act of vandalism but more a revengeful nutter, ie, ex-employee, disgruntled tradie or homeowner, with an axe to grind. I digress, there are calls to register Fire Practitioners/Engineers and to create a SIP Building database, while codes and standards are being reviewed.In a Nutshell Not enough Qualified Expert Fire Engineers and a huge number of buildings to check. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs |
