Browse Forums Building A New House 1 Apr 20, 2018 5:45 pm Hi, we are deciding what sort of roof we can have over our Sheridan 34 alfresco. Clarendon have said they only do proper roof over alfresco. The alfresco is quite large, 10 meters by 3.5 meters and I am worried if we get a proper roof, it will cause the living and dining to be dark inside. Can you share pictures of what you may have done with your alfresco, otherwise comment on whether alfresco does make it quite dark inside? Or has anyone half covered the alfresco with a roof? Thanks anything helpful is appreciated. We can also half cover the alfresco but not sure if that will be enough coverage. Re: Alfresco roof ideas please 2Apr 20, 2018 7:31 pm Tintin444 Hi, we are deciding what sort of roof we can have over our Sheridan 34 alfresco. Clarendon have said they only do proper roof over alfresco. The alfresco is quite large, 10 meters by 3.5 meters and I am worried if we get a proper roof, it will cause the living and dining to be dark inside. Can you share pictures of what you may have done with your alfresco, otherwise comment on whether alfresco does make it quite dark inside? Or has anyone half covered the alfresco with a roof? Thanks anything helpful is appreciated. We can also half cover the alfresco but not sure if that will be enough coverage. Our house isn’t finished yet but I do have photos of our alfresco area which is 95% done... we got a proper roof over ours. But we also have bi-folds which should lighten the kitchen/living/dining area up. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Alfresco roof ideas please 3Apr 20, 2018 7:36 pm If it is on Western or Southern side - makes sense to cover with roof, as it will be either hot (on West) or dark (on South) anyways. If facing North, retractable vergola is a much better solution not only from the natural lighting perspective, but also from the perspective of passive heating during winter. Re: Alfresco roof ideas please 4Apr 20, 2018 8:05 pm Tintin444 Hi, we are deciding what sort of roof we can have over our Sheridan 34 alfresco. Clarendon have said they only do proper roof over alfresco. The alfresco is quite large, 10 meters by 3.5 meters and I am worried if we get a proper roof, it will cause the living and dining to be dark inside. Can you share pictures of what you may have done with your alfresco, otherwise comment on whether alfresco does make it quite dark inside? Or has anyone half covered the alfresco with a roof? Thanks anything helpful is appreciated. We can also half cover the alfresco but not sure if that will be enough coverage. Are you able to add a skylight of some sort? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Alfresco roof ideas please 6Apr 20, 2018 8:48 pm I know some friends who had the same issue with their house but a different builder, they put in 2 big sky lights over the dining and living area and it worked very well viewtopic.php?f=31&t=89059 Re: Alfresco roof ideas please 7Apr 25, 2018 4:43 pm dillongl Tintin444 Hi, we are deciding what sort of roof we can have over our Sheridan 34 alfresco. Clarendon have said they only do proper roof over alfresco. The alfresco is quite large, 10 meters by 3.5 meters and I am worried if we get a proper roof, it will cause the living and dining to be dark inside. Can you share pictures of what you may have done with your alfresco, otherwise comment on whether alfresco does make it quite dark inside? Or has anyone half covered the alfresco with a roof? Thanks anything helpful is appreciated. We can also half cover the alfresco but not sure if that will be enough coverage. Are you able to add a skylight of some sort? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Yes clarendon quoted 3k plus for skylights. However we realized that we could install a skylight inside the home as we have a section in the family room just covered by roof, not first floor of the house. Re: Alfresco roof ideas please 8Apr 25, 2018 4:44 pm CamillaS Tintin444 Hi, we are deciding what sort of roof we can have over our Sheridan 34 alfresco. Clarendon have said they only do proper roof over alfresco. The alfresco is quite large, 10 meters by 3.5 meters and I am worried if we get a proper roof, it will cause the living and dining to be dark inside. Can you share pictures of what you may have done with your alfresco, otherwise comment on whether alfresco does make it quite dark inside? Or has anyone half covered the alfresco with a roof? Thanks anything helpful is appreciated. We can also half cover the alfresco but not sure if that will be enough coverage. Our house isn’t finished yet but I do have photos of our alfresco area which is 95% done... we got a proper roof over ours. But we also have bi-folds which should lighten the kitchen/living/dining area up. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Looks great, love your doors, and also brick selection, is it truffle by Pgh? Re: Alfresco roof ideas please 9Apr 30, 2018 7:47 pm Tintin444 CamillaS Tintin444 Hi, we are deciding what sort of roof we can have over our Sheridan 34 alfresco. Clarendon have said they only do proper roof over alfresco. The alfresco is quite large, 10 meters by 3.5 meters and I am worried if we get a proper roof, it will cause the living and dining to be dark inside. Can you share pictures of what you may have done with your alfresco, otherwise comment on whether alfresco does make it quite dark inside? Or has anyone half covered the alfresco with a roof? Thanks anything helpful is appreciated. We can also half cover the alfresco but not sure if that will be enough coverage. Our house isn’t finished yet but I do have photos of our alfresco area which is 95% done... we got a proper roof over ours. But we also have bi-folds which should lighten the kitchen/living/dining area up. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Looks great, love your doors, and also brick selection, is it truffle by Pgh? Thanks, no the bricks are called chiffon, it’s an urban one range. The lighting can make such a difference, here is one from the front Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Minimum overhang into gutter must be 50mm, turn down tool should not split the sheet. it seems wrong tool for the profile was used, the flashing cannot slope back. Rib… 2 2089 Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4190 |
