Browse Forums Building A New House 1 Apr 12, 2018 9:42 pm Just a quick question re eaves: 450mm vs 600mm. We are buildinga double storey house. 450mm eaves is the standard for all throughout the first floor. Just wondering if extending eaves to 600mm will make a difference to windows on the ground floor? And will you be able to post pictures of your eaves so I can see difference between the sizes. Thanks! Re: 450 versus 600mm eaves 3Apr 12, 2018 11:37 pm Depends on your location but it doesn't it's not much of a change. I've modified my single storey sketchup and raised it by an extra 3meters. You can see the shadow lines below in the middle of summer. For example using the following details Loc: paramatta, nsw Date/Time: Late December around lunchtime Eaves: 450mm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Loc: paramatta, nsw Date/Time: Late December around lunchtime Eaves: 600mm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ So approx 3.26m shadow when measured from under the roof. Re: 450 versus 600mm eaves 4Apr 13, 2018 5:09 am gummz Depends on your location but it doesn't it's not much of a change. I've modified my single storey sketchup and raised it by an extra 3meters. You can see the shadow lines below in the middle of summer. For example using the following details Loc: paramatta, nsw Date/Time: Late December around lunchtime Eaves: 450mm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Loc: paramatta, nsw Date/Time: Late December around lunchtime Eaves: 600mm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ So approx 3.26m shadow when measured from under the roof. I am building in Melbourne west. Oh I see that makes sense so in that case it will only make a difference in the window of the first floor. I've got a west facing window on my living room on the ground floor and checking if it's necessary to extend the eaves just to reduce heat in the area. Re: 450 versus 600mm eaves 5Apr 13, 2018 8:42 am West facing so the afternoon sun. Many things you could do - seperate awning ledge for lower ground window... Maybe a pergola with vines like https://goo.gl/images/aBY8Tm - plant a tree (but no immediate benefit) - build some sort of adjustable shade Play with it and enjoy! Re: 450 versus 600mm eaves 7Apr 13, 2018 8:50 am Use this site to calculate the angle for your area - find your location - zoom in - set the date and also time - set the height so you can see the shadow line (default value is 1m) With a bit of maths you can calculate the the angle and hence the shadow lines for any eaves depth you might think of Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17485 My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance 5 10865 Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5860 |
