Browse Forums Building A New House 1 Apr 05, 2018 6:13 pm I will be using an independent building inspector during the construction of my house in WA. I have been advised, by the inspector, that he will require the engineering plans in order to do his job effectively. The more I think about it I too would also like to know what they are building and in more depth than the general plans that I have been provided with. I have contacted the builder's representative and have been told that they will not releasee the engineering plans citing intellectual property concerns. Just looking for knowledgable input before I speak to someone higher up in the business. Thanks in advance Mark Re: Engineering plans 2Apr 05, 2018 8:20 pm Hi Benno123 That is Salesman's nonsense Go straight to the Building companies Management and lodge a complaint The issues you also have when you use a Building Inspector instead of a Qualified Structural Engineer are 1. Builders make Changes and revisions and these aren't always revised by their Engineer on the drawings? 2. Builders often leave out Construction and engineering details, ie the builder will ask for slab and wind Loading and exclude Masonry and framing 3.Builders would prefer to deal with Building Inspectors than Structural Engineers..Often Claiming changes are 'Alternate methods specified by their engineer"...Yet there is no paperwork? 4. Structural engineers should check everything, even if there is no details...get the gist 5.If you are relying on someone who needs to read engineering details you might as well do it yourself (but unfortunately you cannot) so get an engineer hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Engineering plans 3Apr 05, 2018 8:54 pm Benno123 I will be using an independent building inspector during the construction of my house in WA. I have been advised, by the inspector, that he will require the engineering plans in order to do his job effectively. The more I think about it I too would also like to know what they are building and in more depth than the general plans that I have been provided with. I have contacted the builder's representative and have been told that they will not releasee the engineering plans citing intellectual property concerns. Just looking for knowledgable input before I speak to someone higher up in the business. Thanks in advance Mark Hi Benno123, we’re also currently building in WA our building inspector asked our builder directly for engineer details (hoping this is what you mean) and our builder sent them through not a problem along with our addenda and final plans, can the inspection company ask them directly? Hoping it gets sorted out for you Re: Engineering plans 4Apr 05, 2018 9:02 pm vanessah2015 Benno123 I will be using an independent building inspector during the construction of my house in WA. I have been advised, by the inspector, that he will require the engineering plans in order to do his job effectively. The more I think about it I too would also like to know what they are building and in more depth than the general plans that I have been provided with. I have contacted the builder's representative and have been told that they will not releasee the engineering plans citing intellectual property concerns. Just looking for knowledgable input before I speak to someone higher up in the business. Thanks in advance Mark Hi Benno123, we’re also currently building in WA our building inspector asked our builder directly for engineer details (hoping this is what you mean) and our builder sent them through not a problem along with our addenda and final plans, can the inspection company ask them directly? Hoping it gets sorted out for you Hi Vanessah2015, thanks for your input. I'm just educating/arming myself for the upcoming discussion I intend to have with the builder regarding the engineer detail. I'm sure it will get sorted but I hate going into discussions with no real knowledge of the subject particularly given they have indicated they will not supply the information. Re: Engineering plans 5Apr 06, 2018 2:47 pm Benno123 I will be using an independent building inspector during the construction of my house in WA. I have been advised, by the inspector, that he will require the engineering plans in order to do his job effectively. The more I think about it I too would also like to know what they are building and in more depth than the general plans that I have been provided with. I have contacted the builder's representative and have been told that they will not releasee the engineering plans citing intellectual property concerns. Just looking for knowledgable input before I speak to someone higher up in the business. Thanks in advance Mark If you were asking you were asking a window company for a set of engineering drawings as to how a window frame was designed to comply with a wind or fire rating they could claim IP if it had specific seals etc... I have had 3 versions sent to me from my engineer to make sure I'm happy with how it is to be done so rhere are no issues at certification. Cheers, Pummers. Re: Engineering plans 7Apr 06, 2018 9:15 pm Benno123 thanks Pummers. I'm slowly but surely educating myself on the whole building process. Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 31780 Thanks for all replies. I just noticed now the pictures I added to post right on top of page were wrong. I attached pictures showing "current" and my "suggested" floor… 9 14627 6 11528 |
