Browse Forums Building A New House 1 Mar 16, 2018 11:01 pm We have got a 420sqm lot (14x30) in Brisbane city council area. We would like to build a single story home and it's going to be pretty tight due to setback requirements. I am wondering what's the minimum front and rear setbacks you have seen in Brisbane city council area for a that size lot? Thank you. Re: What's the minimum rear setback in Brisbane city council 2Mar 17, 2018 9:08 am Hi, If I recall correctly.. I spoke to them a month ago! You can call up a town planner, give them your address and they can tell you over the phone.. Its worth the call because they can look at surrounding properties and see what other properties were allowed to doso if they were allowed to do other things you were too.. For e.g. the street I looked into all had car ports and sheds that were closer to the fence line than the standard, so you too can build closer to the fence line due your neighbours changes. But the gist is for the particular area I was looking into.. For non habitable structures e.g. Garage was 1m to the fence line (side), for habitable was 1.5m. For the front the garage had to be 6m from the front. There was a 6m from the back to living areas. Sheds can be built closer to the fence and so did car ports. Also interestingly, could build to 3 levels in a residential area! Not that I had the money to... Re: What's the minimum rear setback in Brisbane city council 3Mar 17, 2018 1:45 pm The BCC Small Lot Code is applicable to lots <450sq.m. It states that the minimum rear boundary setback is 6m for lots deeper than 25m. Side setbacks are 1m for habitable rooms and 0.75m for non habitable rooms. There are other requirements regarding the length and height of the fronting walls, so this is just to give you the general gist. In some cases side setback relaxations (e.g. Built to Boundary applications) can be obtained with the consent of the neighbouring property owner. Regardless, local plans or other codes may take precedence over the Small Lot Code, so the best course of action would be to contact Council and confirm the requirements for your particular lot i.e. don't rely on what someone on this forum tells you! 3 803 Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15716 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8432 |
