thanks
Feedback on house plan
Page 1 of 2
thanks
I would second removing the area outside the bedrooms as you’ve mentioned, and make the family room bigger instead. As it stands it seems too small to be used for much!
Laundry next to BR2 may be a bit noisy. I’m not sure what the solution would be - perhaps have laundry between garage and AV instead?
BIRs in secondary BRs could be wider, if taken right up to door frames (or in the case of BR2 to the edge of the open door).
Main bathroom - I would change to cavity slider door as the current hinged door is interfering with the opening of the shower door. Can you fit a small sink in the toilet cubicle? It would allow for more flexibility of use.
The 'breakout could be around 25% smaller, its better to be generous but as drawn its over generous to no advantage. The door is badly placed. I tend to think about how easy would the house be if someone was injured or an old relative visited who relied on a wheelchair. . . . access to the bathroom visitor toilet etc would be pretty much impossible.
bashworth - have I got the north direction wrong? I tend to get a bit confused with these compasses! Is this plan indicating north is at the garage, or at the alfresco?
I could swap the laundry and bathroom to keep laundry noise away from bed 2.
Definitely going to remove the breakout area and use that space in the living, we will have a spare bedroom anyway for study / activity space
I’ll get the robes and cavity sliding door priced up, i’m expecting these changes won’t be cheap
Thanks for the great feedback
Ah my bad, in that case, consider flipping the design. Rule of thumb - living areas facing north, bedrooms south (or east depending on how you like to wake ), services west.
Oh bugger ok, is that for thermal reasons or just where the light is at different times of the day?
The quality of north light is also better and more “uplifting” so great for the living areas. In this case you could add clerestory windows to get it into your living areas. Unfortunately will add to costs though.
Another thought I had was to add a window to each of the other external walls of MBR, BR3 and BR4, to allow cross-breezes. If privacy is an issue, make it one of those high long windows.
All that before readings Gillybean’s response!
To find the space I'd have to compromise somewhere else....not sure, its so hard to fit everything you want on the tiny blocks being sold these days. When I built 10 years ago I bought a block twice the size for 40k less.
hmm....
Below is energy guide that I tried to apply when designing our house, along with considering our needs and the existing verge tree.
If you can see what I mean in this crude mark up. Flip the island or turn it into a u shape and push the side bench out and put in a wall to block off the scullery. I can do it up a bit better in magic plan if you like.
Building our first custom dream home. https://r.tapatalk.com/shareLink?share_ ... are_type=t
4
Hi there! Absolutely agree on the wasted space. We have no desire for the master to be that oversized, but it occurred when we increased the depth of the garage. We have…
