Browse Forums Building A New House 1 Mar 03, 2018 8:53 am Hi all, Been reading many horror stories about houses being broken into and things stolen immediately after handover. In most cases there are no signs of forced entry, so the insinuation is that’s its an inside job by those who have previously had access during the build. Therefore, is it worthwhile getting the locks changed immediately after handover, or is there some other way to combat this ? Also read somewhere that you should reprogram the garage door, but not sure how you’d go about this. Re: Changing locks necessary? 2Mar 03, 2018 7:35 pm This article explains about the locks that builders use: http://anewhouse.com.au/2012/01/block-boundary-pegs/ I actually moved in on Handover day, although I was really camping in the house until my wife moved in a couple of days later. I also arranged to get curtains installed the same day. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Changing locks necessary? 3Mar 06, 2018 9:56 pm How it worked when I worked for a builder years ago was - The locks will be openable by the builders master key during the build but as soon as you use your individual key for the first time the builders master key will no longer work. Building our first custom dream home. https://r.tapatalk.com/shareLink?share_ ... are_type=t Currently renovating, and our main lounge is 5m x 10m, with a cathedral roof peaking at 6.5m high. Currently have tiles on concrete slab. Room is very hard to heat. I am… 0 4811 How much are you ahead in payments compared to where the build is at? Have you fully drawn down the loan? 5 11906 Hi All, I'm new here! I'm in a block of 4 apartments (Waverley council) and looking to change a window to a sliding door. The window faces an enclosed garden (with a… 0 5536 |
