Browse Forums Building A New House Re: Neighbour build their garage right up the fence line 18Feb 19, 2018 1:45 pm LargeB Have a look at your contract. My contract had a clause in it that said the boundaries may not be exactly as described and there was compensation if the total area of the block fell outside certain parameters. In my case it was +/- 5%. My block was exactly correct so the issue didn't come up. Out of curiosity did you measure yourself from the boundary pegs? What does your survey say? It may be that the pegs are not in the right spot. If that is the case you may need to get it surveyed again and re-pegged. I've measured it based on the cut from gutter where the division of each and every lot. All the fences of different builders in the street are based on that gutter cut as well. That's were I found the issue. Re: Neighbour build their garage right up the fence line 19Feb 19, 2018 1:48 pm Hurrow LargeB Have a look at your contract. My contract had a clause in it that said the boundaries may not be exactly as described and there was compensation if the total area of the block fell outside certain parameters. In my case it was +/- 5%. My block was exactly correct so the issue didn't come up. Out of curiosity did you measure yourself from the boundary pegs? What does your survey say? It may be that the pegs are not in the right spot. If that is the case you may need to get it surveyed again and re-pegged. +/- 5% seems ridiculously high. On a 400 sqm block that could be about a metre off the width, or almost two metres off the length! I agree.. I'll check my contract as well. my lot is 15 x 30 (450 sqm.). I don't think it's right for any owner to loose 22 sqm just like that ... but it's a good point for me to check as well... Re: Neighbour build their garage right up the fence line 20Feb 21, 2018 9:37 pm everistically Hello people I'm building in Elara marsden park (developer is Stockland). Neighbous is still contructing but just realized the their garage is right up in the fence line. I've already heard this issue in other states but not in Sydney. Question is: Is it legal. Or can i still have a word on it before they finish building. Anyhow, is anyone have the same issue. How did you go. I was hoping to put a straight line fence in my property. Hope to hear some feedback This is not an issue and very common in many estates in NSW. It’s called Zero Lot. We see these in contracts all the time for Stockland Elara in Marsden Park and Willowdale as well. Essentially there is an easement on your block (usually around 0.9 metre) for next door neighbour to build right on the fence line and likewise on your block your next door neighbour also has a 0.9 metre easement that benefits you so you can build on their fence line. Common site these days for small blocks or estates in Elara, Riverstone, Schofields and Box Hill. Just allows you to make the most of the space of your land to build that dream home you want to live in. Kind Regards, Bruce "Building an Eden Brae Waldorf 50 in North Kellyville" Blog: http://waldorf50.blogspot.com.au A Mobile Solicitor at Wong & Horta Lawyers Website: http://www.whlawyers.com.au In WA zero lot is actually zero lot. We build 10mm in from the boundary. My house and my neighbours house have garages that sit only 20mm apart. When I had our roof done… 3 7067 I am building in claymore NSW and this is shown in the building envelope plan. … 0 10034 4 10821 |
