Browse Forums Building A New House 1 Jan 23, 2018 4:13 pm I was told by Metricon that they will not upgrage the system to a higher capacity. They give Chromagen Smart Line Solar Water as a standard and if you need a higher capacity you need to add a heat pump 170L at a cost of $1,200. Is this normal or I was mis-informed at Studio? Re: Metricon - Hot water System 2Jan 23, 2018 4:23 pm Clean I was told by Metricon that they will not upgrage the system to a higher capacity. They give Chromagen Smart Line Solar Water as a standard and if you need a higher capacity you need to add a heat pump 170L at a cost of $1,200. Is this normal or I was mis-informed at Studio? Check their applicable listing of STANDARD INCLUSIONS the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14117 The tank is around 200 litres (I am on holiday for the next 6 weeks so can't check) The Heat Pump has a built in time switch. No idea on the speed to heat because with… 6 2152 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20265 |
