Forum Building A New House 1 Jan 20, 2018 8:12 am Hi all I’m looking at getting advice on what can be done. The builder has advised me they poured the incorrect concrete for my slab, the plans and engineering state 25mpa and the builders poured 20mpa. The RBS has issued a fix notice, so the builder has to get this signed off with independent engineer for 20 to be used. Is this correct or should I say I want 25mpa? They have just started the brick work on the house. Location is vic. Thanks for any help in advance. Cheers Simon. Re: Advice and help 2Jan 20, 2018 9:06 pm I think you have a warrenty on foitings and frame, dont see why 20will be okay if report said 25 I would ask for it to be 25 as per report and asper what you were quoted for... and they should bare the cost for the wrong concrete and removal of it... best to get an inspector that can give yoh proper advice and help Re: Advice and help 3Jan 21, 2018 9:09 am You need to re-title this thread and have it moved to the appropriate sub forum. 3 in 1 Supadiverta. 0.75mm filter. No downpipes diverted. Can delete overflow pipe. Cleaner Neater Cheaper Supa Gutter Pumper. An inexpensive gutter overflow solution. https://www.aquatrek.net.au Yeah very true. Thank you so much for your input, it’s really helped. I just wanted to hear all this from a neutral and not just the sale pitch from supplier. What I… 10 712 I’d square off the arch and lower the front door so it’s height matches the top of the windows. The small window I’d delete and have a shrub/tree there (some form… 5 635 ![]() |
