Browse Forums Building A New House 1 Jan 16, 2018 9:31 am Hi! We built our house 8 years ago, and have now decided that we would like to build an investment property in South East Vic. We got the orientation wrong on current home (doesn't bother us too much tho) but I would like to try and get it semi right on the new build. The block is approx 630m2. The front of the block faces east, with the backyard facing west. The crossover is towards the northern side of the block. From what I have researched, it is best to build as close to the south boundary, but I am having trouble finding any plans that would work. Anyone had a similar block and could suggest a plan? As it is only going to be a rental/investment, we don't want to do a custom build, and would ideally like a plan that needs minimal changes. Thanks! Re: Layout suggestions for east facing block 2Jan 16, 2018 9:53 am Our block is 645m and west facing. Only 15m wide so we couldn’t move the house further to the South boundary, so it was just a case of trying to get northern light to our main living areas at the back, and the alfresco. Perhaps run your alfresco all along the back of your house to shield the living areas inside from the afternoon sun. No point having big windows on the northern side if they just look at a fence but if you have a decent width to work with you could. If single storey you could put sky lights in the northern side of the roof. Ours is a double but I wouldn’t do a double for investment purposes. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Monte Carlo 40- Wisdom homes Re: Layout suggestions for east facing block 3Jan 16, 2018 10:26 am Oh sorry, should have mentioned that the block is 18-19 metres wide, so we have enough space to have some yard on the side. All the plans I can find have the garage as the 'dead' side. Re: Layout suggestions for east facing block 4Jan 16, 2018 8:36 pm Just had a quick look on Metricon site. Something like this would work...the main living areas don’t have western windows apart from where the alfresco is for shade, so you can still see our to the backyard. Also don’t forget, if the back wall of the garage lines up with a wall opposite, you can flip the plan just from the garage, and shouldn’t cost much if anything. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Monte Carlo 40- Wisdom homes Re: Layout suggestions for east facing block 5Jan 16, 2018 8:38 pm MandM+4 Just had a quick look on Metricon site. Something like this would work...the main living areas don’t have western windows apart from where the alfresco is for shade, so you can still see our to the backyard. Although I’d continue the alfresco round the side. Also don’t forget, if the back wall of the garage lines up with a wall opposite, you can flip the plan just from the garage, and shouldn’t cost much if anything. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Monte Carlo 40- Wisdom homes Re: Layout suggestions for east facing block 7Jan 17, 2018 9:02 am MandM+4 Just had a quick look on Metricon site. Something like this would work...the main living areas don’t have western windows apart from where the alfresco is for shade, so you can still see our to the backyard. Also don’t forget, if the back wall of the garage lines up with a wall opposite, you can flip the plan just from the garage, and shouldn’t cost much if anything. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks! That plan does looks like it could work. Do you know the name of the plan? Re: Layout suggestions for east facing block 8Jul 25, 2021 2:03 pm what layout did you end up in your build? We are on the same boat. Our block is also facing east and the crossover is on the northside. The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18194 Keen to hear from people in the area who have got KDRB done on whom they got the build from? Looking for recommendations. Thanks 0 21099 It might be a bit darker in the mornings but the light is still light, so you should be getting it. Similar to what you see from your western windows 3 19987 |
