Anyone know how hard or easy it is to get the mains water tap moved? Now frame is up, just realised ours is right where the path needs to go to our front door.
Browse Forums Building A New House Re: Moving mains water tap - hard to do? 4Jan 14, 2018 7:48 am Ezza78 Thanks DaniJ, so is it the council I need to speak to or south east water? Speak to the water company Our 37sq Custom Hamptons Inspired Home: http://forum.homeone.com.au/viewtopic.php?t=86931 if it's the look that you're not happy with, the easiest option would probably be to spray paint it all into the same color as the walls so it blends in. there might not… 3 4192 Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1670 5 10493 |
