Browse Forums Building A New House 1 Jan 09, 2018 10:09 pm Hi All What items require to be of Australian Standards when fitting into a new home?. I know taps, electrical ( does that mean all switches, junction box'es and wiring) So apart from timber , bricks and tiles what else can we order for our house. We just found out the builder is using imported goods so we might as well do it ourself! your advice appreciated for our new build Re: Australian Standards - Imported Supplies 2Jan 10, 2018 7:52 am There are australian standards for everything check out Sai Global and at $hundred$ a pop, a good designer and engineer should have subscription access to the standards BTW, Imported Materials & Internet purchases have also been discussed here Ebay stores ... goodluck Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7005 I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more… 4 5153 2 8645 |
