Browse Forums Building A New House 1 Jan 03, 2018 1:01 am Hi Guy's We are just starting out with designing our custom design home and was looking for a bit of inspiration from fellow homeone users. I am looking for help with the layout of the kitchen, meals, living, laundry and pantry. I feel the cooking area is too small at the moment and would like help rearrange that area. What are your thoughts? Thanks in advance for your help https://1drv.ms/i/s!AjTYw4riAKnpnnx4LO-Odo7sM9Km Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Help required with plan for custom design home layout 2Jan 03, 2018 9:51 am You look to be running out of usable wall space. A couple of small modifications would be:
The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Help required with plan for custom design home layout 3Jan 03, 2018 8:21 pm I'd turn the entire kitchen / island around 90 degrees to the right so the bench area runs into the pantry. Re: Help required with plan for custom design home layout 4Jan 04, 2018 3:57 am I highly recommend magic plan app. It took hardly anytime at all for me to do up these. If you put your plan in and have a play with it you can see what suits you guys best. I think keep the orientation you have if you want it to be facing your outdoor area and then you can have a larger island. I personally don’t like the sink in the island because it uses up my prep space and when I have the kids at the island doing their homework I just like the dishes and sink to be out of the way but this island is 4m long so more than enough room for a sink in it. I’ve put both pictures up. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building our first custom dream home. https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: Help required with plan for custom design home layout 5Jan 04, 2018 4:00 am I think recessing the fridge always looks classier and a cavity slider to the pantry let’s you keep it open and easy access to everything in there but the option to close it if you want to hide it. Building our first custom dream home. https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: Help required with plan for custom design home layout 6Jan 29, 2018 12:30 pm Hi guy's, Thanks for your ideas. Having looked at it again I have adjusted the lay as per the attached picture. What do you think of this layout now? Link to PDF for Ground and L1 drawings Thanks for your time. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ ideal house depends on the site and location as much as internal floor plan....what is the distance from the house to all four boundaries, where is north, describe your… 3 15156 Hello! We have a very large open plan living room and wanted to get layout options, and furnishing ideas for this space. Currently there is only a… 0 9322 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25163 |
