Browse Forums Building A New House Re: rendering the facade 3Dec 07, 2017 8:24 pm If your estate is a new estate, the sales office will be able to provide you with any guidelines you need to follow. If an older estate, the requirements should be listed in your sales contract for the land. Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7412 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4865 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5222 |
