Browse Forums Building A New House Re: First Build with Summit Perth WA 201Mar 18, 2018 10:00 pm my new build thread- Ben Trager https://forum.homeone.com.au/viewtopic.php?f=31&t=89826 my switch build thread (2011) https://forum.homeone.com.au/viewtopic.php?f=31&t=36569 Re: First Build with Summit Perth WA 205Mar 18, 2018 11:22 pm my new build thread- Ben Trager https://forum.homeone.com.au/viewtopic.php?f=31&t=89826 my switch build thread (2011) https://forum.homeone.com.au/viewtopic.php?f=31&t=36569 Re: First Build with Summit Perth WA 213Mar 21, 2018 4:24 pm we upgraded the aircon ducts and possibly the must-haves along with AirTouch controller. I can switch on aircon away from home and we hardly need to use aircon at our place as we also went for Anticon under the roof. We use aircon for about 30 minutes and the whole house remains very cool without any fans. Mind you we have windows all along our northern side of the house. Re: First Build with Summit Perth WA 215Mar 21, 2018 5:36 pm Thanks for your replies everyone. I decided to upgrade the controller, as you’ve both said the ability to have more control of your system both from within and outside the home is a great benefit & great for the bottom line. I added an outlet to my ensuite and a zone to seperate beds 2 & 3. I slightly moved my master suite outlet however the rest looked okay to me. Looks like my return vent will be in my second hallway instead of main so I am super happy with that. I decided against upgrading the ducting as nobody could really confirm that it was worth it. The anticon brings me to another query, is there any insulation installed in the roof cavity with colourbond being the roof material? That was not something I can recall being offered at pre-start (wall? Insulation was) so I assumed there would be something of the sort being supplied for the roof? Re: First Build with Summit Perth WA 216Mar 21, 2018 5:47 pm Summitlovin The anticon brings me to another query, is there any insulation installed in the roof cavity with colourbond being the roof material? That was not something I can recall being offered at pre-start (wall? Insulation was) so I assumed there would be something of the sort being supplied for the roof? yes there is going to be insulation in the roof and anticon was just an additional layer right under the colorbond. This is extra that you have to request we also only found out quite late about this. From memory, it was about 5K extra on the whole roof. Re: First Build with Summit Perth WA 217Mar 21, 2018 11:16 pm jpmontoya Summitlovin The anticon brings me to another query, is there any insulation installed in the roof cavity with colourbond being the roof material? That was not something I can recall being offered at pre-start (wall? Insulation was) so I assumed there would be something of the sort being supplied for the roof? yes there is going to be insulation in the roof and anticon was just an additional layer right under the colorbond. This is extra that you have to request we also only found out quite late about this. From memory, it was about 5K extra on the whole roof. yep, the budget says no deal to the anticon! haha but thank you for the info. I thought they would have to of had some insulation for the colourbond Re: First Build with Summit Perth WA 218Mar 22, 2018 12:50 am Once step closer to getting the roof on, hopefully very soon. Re: First Build with Summit Perth WA 219Mar 22, 2018 5:20 pm hi guys. Please be nice. First time home builder in Qld. I would like some feedback please on whether I should build my granny flat first before my main house at the… 0 4956 So still no slab and apparently the concreter cancelled. Here come the delays... apparently things haven't recovered quite as much as I thought. I've been told maybe next… 8 31825 Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 19092 |
