Browse Forums Building A New House 1 Dec 01, 2017 11:04 am I went by the house last week and the tiles had been delivered. I took a picture of the delivery receipt and when I got home I compared it to our contract and it was the wrong tiles for the backsplash. We chose City Grey Gloss STRUCTURED and they got City Grey Gloss. The difference is the structured one has th 3D effect whereas the other is flat. The next day we contacted them and it had already been installed. They said the one we chose was discontinued so they got that one. Thing is, we weren’t notified of any changes. Will they charge us to remove the tile? Has this happened to anyone, if so what happened? Or what should happen in this situation? Thanks Re: Builder put in the wrong backsplash, what’s next? 2Dec 01, 2017 2:01 pm 2017istheyear I went by the house last week and the tiles had been delivered. I took a picture of the delivery receipt and when I got home I compared it to our contract and it was the wrong tiles for the backsplash. We chose City Grey Gloss STRUCTURED and they got City Grey Gloss. The difference is the structured one has th 3D effect whereas the other is flat. The next day we contacted them and it had already been installed. They said the one we chose was discontinued so they got that one. Thing is, we weren’t notified of any changes. Will they charge us to remove the tile? Has this happened to anyone, if so what happened? Or what should happen in this situation? Thanks If you go to your contract it should state that if the builder has to change something that cannot be supplied as per contract , the owner needs to be notified and a variation put through. If YOU don't like the ones that have been put up, the BUILDER has to take them off and YOU should be the one to choose a different one. Don't be bullied by them. They can't just pick and choose what they want. It's your money, your house and the choice is yours. (As you can tell I'm kind of fed up with these builders!!!!) Good luck Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16054 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18318 Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20217 |
