Browse Forums Building A New House Re: Building inspector worth it? How was your experience? 7Nov 30, 2017 4:01 am I engaged someone in sydney - one of the biggest names, and i ended up picking up more than they did. In fact they passed the slab without issue, only for me to point out a number of issues! Needless to say they refunded my money and that was that. I think absolutely get an inspection but don't let your own standards drop- do your research and make sure you check why you can yourself with the knowledge you have, and if there's anything that you're concerned about that the inspector doesn't pick up, raise it with them. The more eyes the better M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Building inspector worth it? How was your experience? 8Nov 30, 2017 5:48 am I would definitely not build without a private inspector. This is our second build and this one is our family home. We are in Melbourne using Darbecca and we are actually getting a reinspection today as we have issues that have Engineering specs for the rectification. It's a small spend in the overall price of the home and for me, peace of mind. We have gone with Darbecca due to the number of others on social media that have recommended them. My experience with them has been wonderful, they are great to work with. We didn't fully comprehend our last report and the inspector was happy to explain it for us and to advise what issues needed to be fixed immediately and what could be completed down the track. Well worth the money. Good luck with your build Re: Building inspector worth it? How was your experience? 9Nov 30, 2017 10:02 am Hey all, Just wanted to share an update on this. Basically I got quote from one of the inspection company. In the process of getting quote from other one now. Obviously I need someone who has been in the industry for many years and someone who is very thorough. Especially don't want to see any cracks in the walls down the line as our soil has been classed as "P" (problem soil). Hence need to ensure no corners are cut in foundation etc. Will update you once I have chosen particular inspection company. Not in a great rush as our build is still probably couple of months away. Hoping things go pretty well from here on. Looking to build a home in VIC. Land titled in November 2017. Construction started in February 2018. Double storey 37sq. Re: Building inspector worth it? How was your experience? 11Nov 30, 2017 12:28 pm rum_home Who is the 'independent' building surveyor your builder has forced you to use? Or is this your primary surveyor company for the build? I am not sure what you mean here. Can you elaborate. I don't know anything about surveyor. Looking to build a home in VIC. Land titled in November 2017. Construction started in February 2018. Double storey 37sq. Re: Building inspector worth it? How was your experience? 12Nov 30, 2017 12:46 pm Loveguru I am not sure what you mean here. Can you elaborate. I don't know anything about surveyor. Sure, you didn't get any documentation from your builder regarding the appointment of an independent building surveyor? You should have received a VBA fact sheet on appointment of a private building surveyor? Re: Building inspector worth it? How was your experience? 13Nov 30, 2017 1:06 pm rum_home Loveguru I am not sure what you mean here. Can you elaborate. I don't know anything about surveyor. Sure, you didn't get any documentation from your builder regarding the appointment of an independent building surveyor? You should have received a VBA fact sheet on appointment of a private building surveyor? Thanks, I will look into this as well further. I didn't receive any information regarding surveyor from builder. Looking to build a home in VIC. Land titled in November 2017. Construction started in February 2018. Double storey 37sq. Re: Building inspector worth it? How was your experience? 14Nov 30, 2017 1:30 pm Loveguru Thanks, I will look into this as well further. I didn't receive any information regarding surveyor from builder. Have they just said you have to supply your own? If that is the case they usually have a lot of conditions to who you must choose from, and their capabilities and liabilities. http://www.vba.vic.gov.au/consumers/bui ... g-surveyor http://www.vba.vic.gov.au/__data/assets ... nt-PBS.PDF Re: Building inspector worth it? How was your experience? 15Nov 30, 2017 1:56 pm rum_home Loveguru Thanks, I will look into this as well further. I didn't receive any information regarding surveyor from builder. Have they just said you have to supply your own? If that is the case they usually have a lot of conditions to who you must choose from, and their capabilities and liabilities. http://www.vba.vic.gov.au/consumers/bui ... g-surveyor http://www.vba.vic.gov.au/__data/assets ... nt-PBS.PDF Builder hasn't mentioned anything about surveyor whatsoever.. Looking to build a home in VIC. Land titled in November 2017. Construction started in February 2018. Double storey 37sq. Re: Building inspector worth it? How was your experience? 16Dec 01, 2017 7:21 am Loveguru Builder hasn't mentioned anything about surveyor whatsoever.. In Victoria, it is illegal for the builder to appoint the surveyor, the building surveyor must be appointed by the buyer. You need to check this for very obvious reasons. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Building inspector worth it? How was your experience? 17Dec 01, 2017 10:38 am I think having a building inspector is handy particularly for an untrained eye, but keep in mind: 1. They generally pick up the same common faults time and time again (as they do it every day). Their reports tend to be "cookie cutter" in approach. I've compared my own reports of a major inspector against reports from other H1 members and the language is nearly identical. 2. They will always pick something up, as they need to give the perception that the client is getting their monies worth. 3. A lot depends on the willingness of your builder to rectify. If you have a difficult SS and Construction Manager, then a report is useless unless you can compel/enforce the fixes. I would send it to the certifier who is technically your representative and working on your behalf not the builder's 1 2504 Carlisle use to sneak a water resistant "Performance Solution" into their contracts. Have you checked your contract for same? 4 11165 I do enjoy the drama:-D In his latest two videos he has started bringing security guards to site, I am waiting for the punch on to begin lol 6 46192 |
