Browse Forums Building A New House 1 Nov 20, 2017 7:17 pm Hi , We are currently building a single level 32sq meter house with 2.6m ceiling height. We are currently up to final painting and we have noticed a expansion joint in our main hallway The builder never indicated we would need an expansion joint, is this a common practice for new house builds? should they have notified us prior to building . Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Help ceiling expansion joint 2Nov 21, 2017 5:47 am JSESTAGE1B Hi , We are currently building a single level 32sq meter house with 2.6m ceiling height. We are currently up to final painting and we have noticed a expansion joint in our main hallway The builder never indicated we would need an expansion joint, is this a common practice for new house builds? should they have notified us prior to building . Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We are soon to be building and received our soil report which states we need expansion joints in the ceiling and flooring. This is to allow for movement of the house so the plastering doesn't crack. it would have been mentioned in the original soil report. Re: Help ceiling expansion joint 3Nov 21, 2017 8:02 am Hi Thanks for your reply, Just checked soil report and it doesn't mention any need for expansion joints in the ceiling Re: Help ceiling expansion joint 4Nov 21, 2017 10:26 am jsesTAGE1B Check your Engineering drawings for expansion joints? Are you using steel framing? Not only does that look ugly it could possibly be incorrect (builders mistake?).. seek the engineers clarification Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Help ceiling expansion joint 5Nov 21, 2017 10:58 am Hi Thanks for your reply, I checked all my engineers reports and it isn't drawn in on any plans, do you know the maximum span before a expansion joint is needed ? Thanks Re: Help ceiling expansion joint 7Nov 21, 2017 7:25 pm jsesTAGE1B Sorry more questions Is it shown on your floor plans, construction details, anywhere? Is your roof framing trusses? How long is your passage? Expansions coefficients here Gyprock Engineering properties Control Joints page 30 Gyprock Installation guide Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Help ceiling expansion joint 8Nov 21, 2017 8:10 pm Hi Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Attached are our construction plans and also roof truss plan. I would say it is approx 7m from front door, it is the only visible ceiling join in the house. Your feedback is much appreciated I check over all plans today and it does not mention it anywhere. Help ceiling expansion joint 9Nov 22, 2017 6:07 am That is an awfully long run from the front door to the back of the living area (around 20m). Your builder is the one who provides you warranty, and sometimes they do something that was missed by designers and engineers. He probably thought it was warranted. No doubt if he didn’t put in an expansion joint, you would have concerns if after a year a crack appeared in a random place along that run length. He should have discussed it with you at some point to decide where to put an expansion joint, but I think including one is reasonable. Re: Help ceiling expansion joint 10Nov 22, 2017 7:32 am JsesTAGE1B Thanks for the info There is a need for a break in the ceiling but he could have placed &/or disguised it better Personally I wouldn't accept that. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs To my understanding early saw cuts are to control shrinkage cracks, so doing them now would be pointless. Control joints may reduce ugly cracking during periods of soil… 3 9858 Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks 0 10939 Hi, I am planning to select San Selmo reclaimed original for the fascade of my build. I have seen many photos on line of the brick varying from a rustic to a neat finish.… 0 4577 |
