Browse Forums Building A New House 1 Nov 18, 2017 12:29 pm I'm trying to wrap my head around this whole sub division process. In Avondale Heights, Vic, 3034 to subdivide you need 250m unless its under the flight path then you need 300m. If you look at this property, https://www.realestate.com.au/sold/prop ... -125751682 which is approx 845m, if you check here http://services.land.vic.gov.au/maps/pmo.jsp you can see the number of around 850m is right. Now that means you can only fit 3 houses on it, yet looking now online they have built 4... https://www.realestate.com.au/property/ ... s-vic-3034 https://www.realestate.com.au/property/ ... s-vic-3034 https://www.realestate.com.au/property/ ... s-vic-3034 https://www.realestate.com.au/property/ ... s-vic-3034 How could this have been done? Re: How did they build 4 properties on this land? 4Nov 18, 2017 3:20 pm wow my bad... I assumed being 16 A-D it was just the number 16 property split into 4. Hi, just need to ask if anyone build with Central Properties in Victoria. Thankd 0 4073 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 14608 |
