Browse Forums Building A New House 1 Oct 19, 2017 3:49 pm We received our final plans this morning and going over them we're not sure about the placement of a downpipe. I'll attached 2 images. The first one is of the facade we have chosen. The facade has a post that we really like. In the plans, there is a down pipe on that post. That seems very out of place to us. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Opinions on down pipe placement please 2Oct 19, 2017 4:19 pm It would be less noticeable if a brick pier was used rather than a post. I would suspect that the right side of the garage door could also be possible. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Opinions on down pipe placement please 3Oct 19, 2017 4:52 pm bashworth It would be less noticeable if a brick pier was used rather than a post. I would suspect that the right side of the garage door could also be possible. I'm thinking it might be better on the garage wall behind the post if that is possible. Hi all, My first post, we are building a house and can’t decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow… 0 13732 Move your linen into laundry and access laundry from your present linen space 1 8017 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7331 |
