Browse Forums Building A New House Re: Building with Hall & Hart Homes 996May 13, 2020 2:48 pm ocean Zen ocean Is anyone happy to give a ballpark of where there electrical appointment came in. I can see above that kitchen/bathroom upgrades may be into the vicinity of $25K Trying to then think ahead to electrical: - Light/fans - More power points - More zones for air con - external lighting ...... Any indicative figures or other things to think about? Really appreciate all the advice on this forum! Strip lighting under kitchen cupboards Airplane lighting/strip lighting on stairs/hallway Any other ideas? Just quick one on stair lighting - we provisioned fittings for every 3 steps on our stairs and recently got the stair lights installed. Having a light per 3 steps (even though this was recommended in our electricals appointment) is way too bright. Also once you add up the batten provision plus cost of the stair lights (surprisingly expensive esp if you bought 5 like we did) plus sparky labour - it gets expensive. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks Zen. I wonder what the alternate is. BTW What is your carpet?! It looks fantastic! Hope you are settling in well. Hi ocean, depending on how your staircase is oriented, you could put one wall light high up on the wall facing the landing so it casts light on both landings - the only thing is it takes up wall real estate where you might want to put art/photos. If we could re-do, we would just have 1 stair light on each landing and 1 stair light on the wall facing both landings, so 3 in total. We love our carpet too - it's a closed loop and was a recent addition to the range at Accent - brand: ec, name: Acacia Hill, colour: Longford 1252 BTW, we also got strip lighting under kitchen cabinet from elba, cost approx $450 from memory. Re: Building with Hall & Hart Homes 997May 13, 2020 8:08 pm ocean Jacks Bit of a request for anyone who has finished their build - can I please ask if you wouldn’t mind taking a photo of the alfresco roof as we’re trying to understand what “standard” is in regards to the finish as apparently it doesn’t include a perimeter beam to keep the weather out even though this is part of both the sienna and Elyse display homes. So a little confused as to how the roof is finished under the gutter. Thanks so much! Hi Jacks we are now looking at this too - I just searched to see what others said and found your post. What did you end up doing? Thank you. ocean, is this what you’re after? Our alfresco has a beam around the perimeter. Can see this more clearly from inside the alfresco but I don’t have a pic from Inside. Can take one tomorrow if you are interested. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Hall & Hart Homes 998May 13, 2020 9:51 pm Zen ocean Jacks Bit of a request for anyone who has finished their build - can I please ask if you wouldn’t mind taking a photo of the alfresco roof as we’re trying to understand what “standard” is in regards to the finish as apparently it doesn’t include a perimeter beam to keep the weather out even though this is part of both the sienna and Elyse display homes. So a little confused as to how the roof is finished under the gutter. Thanks so much! Hi Jacks we are now looking at this too - I just searched to see what others said and found your post. What did you end up doing? Thank you. ocean, is this what you’re after? Our alfresco has a beam around the perimeter. Can see this more clearly from inside the alfresco but I don’t have a pic from Inside. Can take one tomorrow if you are interested. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks so much! Exactly what I was after - the beam around the edge. Re: Building with Hall & Hart Homes 999May 13, 2020 10:29 pm Zen ocean Jacks Bit of a request for anyone who has finished their build - can I please ask if you wouldn’t mind taking a photo of the alfresco roof as we’re trying to understand what “standard” is in regards to the finish as apparently it doesn’t include a perimeter beam to keep the weather out even though this is part of both the sienna and Elyse display homes. So a little confused as to how the roof is finished under the gutter. Thanks so much! Hi Jacks we are now looking at this too - I just searched to see what others said and found your post. What did you end up doing? Thank you. ocean, is this what you’re after? Our alfresco has a beam around the perimeter. Can see this more clearly from inside the alfresco but I don’t have a pic from Inside. Can take one tomorrow if you are interested. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi Zen That beam was a standard finish and not upgrade right? I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8814 Ask for references and speak to them. If they are defensive or try to avoid the request, walk. 1 74701 I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with… 14 105551 |
