Browse Forums Building A New House Re: Building with Hall & Hart Homes 580Feb 24, 2019 8:18 am Amanda_Ly Thanks kjane! More photo's of the facade closer to completion would be great! I remember there was a triangle window in the front bedroom of the display home as I was told this shape cannot be changed, do you know if this is true? It will be hard to find the right window covering for a triangle window. I am also wanting to frame all windows on the facade, do you know if it's possible to have the brick ledge removed for framing? My plans are due back next week! Hi Amanda, Good luck with getting your plans back! Exciting times. I'll hopefully post some more photo's of the façade at the end of the week. Our lower level roofing was due to be completed this week but it's rained all week so no roofing work was possible. I'm thinking the window you are talking about is bedroom 4 upstairs? We changed it from the triangle to rectangle for the same reason of window furnishings and also increased it to the maximum height and put width to 2170mm. We also have the second window in this bedroom (no change from plans) which is the standard 850mm wide. Lots of light in this room now. I'm not sure about removing the brick ledges for framing but drop them an email and they should be able to let you know. Looking forward to hearing how your plans turn out I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8814 Ask for references and speak to them. If they are defensive or try to avoid the request, walk. 1 74701 I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with… 14 105551 |
