Browse Forums Building A New House Re: stormwater plan 3Aug 26, 2008 9:46 pm Start: 15 May 08, Current: Handover inspection 19/09 after that, the house is ours!! Visit our blog: http://loveourgerbera.blogspot.com/ Re: stormwater plan 5Aug 26, 2008 9:58 pm Start: 15 May 08, Current: Handover inspection 19/09 after that, the house is ours!! Visit our blog: http://loveourgerbera.blogspot.com/ Re: stormwater plan 9Aug 27, 2008 6:00 pm Well I think the building co has ripped us off $150, because when I rang today to get them to do it, the cs said that she will send out the variation paper to sign. In our contract 'stormwater' is to be done by owner. So why do I think they have ripped us off...because they have built in the same estate, they have at least 5 houses they are building, so knew exactly what had to be submitted to council, but they waited until final contracts were signed, plans sent in to council, then let us know. So basically the $150 is a variation fee, something that could have been sorted out at our pre-start meeting. Re: stormwater plan 10Aug 28, 2008 12:21 pm hi,
150 is a bargain, ours cost 480 for an engineer to draw plans for our surface stormwater. Just hope your 150 doesn't turn into thousands of dollars as you may have to do extra piping and plumbing for the stormwater. Re: stormwater plan 11Aug 29, 2008 2:01 pm Quote-'Well I think the building co has ripped us off $150, because when I rang today to get them to do it, the cs said that she will send out the variation paper to sign'
Dont get too dispondant about this $150 dollars, in the scheme of things its a very small drop in the ocean. Its when the variation figures get into 4 and 5 figures that you should start getting your boxing gloves on. Quote-'In our contract 'stormwater' is to be done by owner' Lastly, stormwater layouts is something very basic that should have been put on your site plan, prior to council submission, it is standard practice. Conclusion-Read your contract very carefully, there may be other surprises in there your not aware of. Pat the draftie. Re: stormwater plan 12Aug 29, 2008 5:23 pm Even if the stormwater was 'to be done by owner', the layout & discharge should have been included on the submitted drawings. The builder would know this or at least who ever drew up the plans would.
$150 for 15 to 30 minutes on cad - not bad money. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4906 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8558 in the stormwater pit or the drain? Those dont look like theyd fit in the drain. Separately, the pits do get stuff in them during the course of the build. For the most… 1 7978 |
