Browse Forums Building A New House 1 Oct 01, 2017 1:12 pm Hi I am building a GJGardner Stillwater and the plumbing has just gone in. I am worried my plumbing looks a bit sloppy. All the other homes I have looked at at the same stage of the build as us. Have their building run along the top of the roof. But ours runs near the ground, under windows all the way down one side of the house. Should we be concerned? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Should my plumbing look like this? 3Oct 01, 2017 1:31 pm The shortest distance =less friction loss and less water wasted while waiting for the hot water to arrive. The plumbing has been properly thought out. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Should my plumbing look like this? 4Oct 01, 2017 1:33 pm Mt.view I`m not a plumber but the work looks pretty sketchy What is "sketchy" about it? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Should my plumbing look like this? 5Oct 01, 2017 1:52 pm To us it makes sense to run it above windows and doors (i.e. along roof line )as you minimise the risk of putting up a shelve and bursting a pipe in your home. Re: Should my plumbing look like this? 7Oct 01, 2017 1:59 pm Stacca To us it makes sense to run it above windows and doors (i.e. along roof line )as you minimise the risk of putting up a shelve and bursting a pipe in your home. They would have to be very low shelves. It is good to see that the builder has properly graded the site slope away from the slab and also installed temporary downpipes. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Should my plumbing look like this? 8Oct 02, 2017 6:34 am The pipes are in the cavity therefore on outside of the stud wall. It is unlikely that any fixing of shelving will go right through stud and puncture a pipe. Yes piping could have been a bit neater but at least it is clipped to studs. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Should my plumbing look like this? 9Oct 02, 2017 11:12 am If what your worried about is the pipe not running dead straight then be assured that most Flexi pipe is installed like that with curves and sweeping bends. To me, yours look neat. The outdoor thing is new to me as I'd generally seen them in the roof and hollow internal walls. Your more likely to hit the pipe if drilling completely through the bricks from the outside and manage to punch through the hole brick. The pipes are low but if you're ever wall mounting a clothes line or hose reel just be mindful of their location and the drilling depth. No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11704 In my experience roof is essential element of the building envelope and hence a common property and should be covered by owners corporation however a detailed review of… 3 6209 For anyone that comes across this issue in the future - Just did what aussieta said and found a plumber to inspect it and sign off on it. Was difficult to find someone to… 3 7092 |
