Browse Forums Building A New House 1 Sep 04, 2017 8:09 am z M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Squeaking floor 3Sep 04, 2017 8:49 am Write reply... M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Squeaking floor 4Sep 04, 2017 10:36 pm That's concerning, sometimes squeaks etc can be from a lack of adhesive (liquid nails) underneath the yellow tongue this seems much more significant than lack of glue/nails Could be steel rubbing, lack of fixings/joist hanger hardware etc into posi struts/floor joists or a combo of everything Re: Squeaking floor 5Sep 05, 2017 4:20 am x M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Squeaking floor 6Sep 05, 2017 7:00 am Could be multiple things, if there is any access in the subfloor would be good to check in there, otherwise pop some down lights or anything like that out grab a torch and get your partner to walk around again and have a look, see if you can narrow some things down Re: Squeaking floor 7Aug 05, 2018 12:21 pm MrsJM Coral have told me once that steel making noise is normal... but really??? This is normal after 9 months?? This is what it sounds like when my hubby is just walking around normally upstairs and I am downstairs. Edit: video link kindly posted below thank you Has the squeaky been fixed? Stopped 100%? I probably have the same issue, different builder CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16538 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17511 Hi We have Hybrid Spotted Gum Hp0995 from carpet call. It turned out to be very dark and rough. Is there any polish or product we can use to make it shinier ? 0 9183 |
