Browse Forums Building A New House 1 Aug 31, 2017 12:26 pm Hi all, We have been advised by our builder that because of the contouring of our lot, our external laundry door will need to have a landing and stairs (in order for us to be able to safely step out of the door to the backyard). We were not previously informed of this (they actually changed our door to a window and thought we wouldn't notice!) and now they are trying to charge us $5,000 to put a landing, stairway (on either side of the landing) and balustrade. We said if it costs that much then just leave it and we will build it ourselves on completion. But they said they can't do this and that they are required to ensure there is a landing and stairs. In that case, shouldn't they pay for it? It's not our fault they didn't take it into account! Has anyone been through something similar? What's a reasonable price for a concrete landing? Any help would be much appreciated! Re: External stairs and landing 4Aug 31, 2017 5:34 pm They can still complete the build as contracted, and gain an interim occupancy certificate to handover you you upon completion. IF you do need a landing and stairs, you will just need to have this completed before you can get your full occupancy certificate Re: External stairs and landing 5Aug 31, 2017 5:47 pm This seems like a mistake by the builder and they should cover the costs of what's required. Assuming the plans show stairs and landing etc and there isn't anything in the quote/contract regarding no allowance for stairs etc then it seems it's an unforeseen by the builder, which should've been picked up on when estimating at least I can see it from the builders side of things, to me if I made the mistake and approached the client about an extra for it I would be unlikely to charge the full cost Re: External stairs and landing 6Aug 31, 2017 6:09 pm Thanks guys! Yeh they have quotes something ridiculous, and now that I have said it is ridiculous excessive, they have given me a 50% discount. Seems a bit suss to me! There is nothing on the plans about putting stairs outside of our laundry so I think I will push it that it's their issue and they need to cover the cost. Re: External stairs and landing 7Aug 31, 2017 6:36 pm Have you signed a contract? I'm sure I saw something in our contract about the builder not being able to change for errors or omissions if that information was available to them prior to drawing plans. They should have been able to figure out that it was too high from the contour plans. Re: External stairs and landing 10Aug 31, 2017 10:27 pm what state are you in? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: External stairs and landing 12Sep 01, 2017 9:51 am lys245 What does your site plan say..in regards to Finished floor plan levels (FFLs) inside the house and Ground plan Level (GL) outside, did they make a mistake with the fill/cut levels..You will need to provide more info. Don't put whole plans up showing builders name etc. crop image or leave a PM if you wish not to mention/provide builders details...hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs 2 2954 I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 12022 You will need to replace the entire stairs. Carpenter is the trade you're after. 1 4366 |
