Browse Forums Building A New House 1 Aug 25, 2017 3:55 am New build I was out there today and there is about 50mm gap that runs down the hallway wall that backs on to the side of my garage wall about 6meters long how will this gap be filled in the hall way side and will this promote movement and cracks down the track Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: gap from slab of internal hallway wall 2Aug 25, 2017 8:30 am I had the same thing. It basically gets filled with cement. If floor tiles are going in there make sure they use a flexible adhesive. If you have skirting boards then any minor cracking should be covered by them. First home builder - Brightwood Estate, Baldivis. Celebration Homes. Follow my build here Re: gap from slab of internal hallway wall 3Aug 25, 2017 9:03 am What's was there excuse for the gap looks to me as a miss measure on the slab pour Re: gap from slab of internal hallway wall 4Aug 25, 2017 9:22 am @erecttvantennas Its either the designers, slab or the bricklayer..sorry to be stating the obvious. 1. Check the slab against the drawing dimensions they should be in increments of brick length +10 mm ie 290 + 10 =300 mm 2. Check the brickwork with a tape measure it should be No of bricks x 300 -10 ie 10mm x 300-10= 2990 mm That just indicates the designer, SS & trades didn't check the work..not a good sign Make sure it's waterproofed properly OT You should get onto poor workmanship quickly. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs 2 7438 Might cheaper to changer your idea of what makes a home, have you considered building a porch? 2 51774 at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61339 |
