Browse Forums Building A New House 1 Aug 11, 2017 11:38 am Hi Everyone, If you have any quesions about your energy rating, or Low-E, Double Glazing, uPVC, Aluminium, U-values, SHGC, acoustics (noise), or anything to do with windows and doors, I will answer all questions, technical, aesthetic or practical. In addition, if you have problems with windows and doors, ask away. Thanks Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Low-E, Double Glazing, uPVC, Aluminium, U-values, SHGC 2Aug 11, 2017 11:48 am Nice post, thanks Ed. Quick one for you. We have double glazing everywhere except one window, as it is a frameless corner window which Metricon refused to double glaze. It is west facing, master bedroom. I'd like to put both reflective film on the outside, and also double glazing film. First of all, is that possible to have both products together, and secondly - is double glazing film effective? Thanks in advance. Re: Low-E, Double Glazing, uPVC, Aluminium, U-values, SHGC 3Aug 11, 2017 12:19 pm What is a frameless corner window? Is that sashless? Butt joined? Double glazing film is of little use... can I see your plans & elevations at that window. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Low-E, Double Glazing, uPVC, Aluminium, U-values, SHGC 4Aug 11, 2017 1:24 pm Is Low-E worth it as we have to have Low-E on our two sliding doors which are 3.6m long. (To meet 6 Star Rating). They have mixed Double glazing with Low-E to meet target. Edit: The Sliding doors are west facing. Re: Low-E, Double Glazing, uPVC, Aluminium, U-values, SHGC 5Aug 11, 2017 1:35 pm ECOECO What is a frameless corner window? Is that sashless? Butt joined? Double glazing film is of little use... can I see your plans & elevations at that window. Ed Thanks Ed, fixed butt joined window. West elevation Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ North elevation Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Low-E, Double Glazing, uPVC, Aluminium, U-values, SHGC 6Aug 11, 2017 1:45 pm It is possible to double glaze butt joined windows, but hardly ever does anyone do it. It leaves a black joint in the corner where the spacer bars overlap. Single glazed is neater. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Low-E, Double Glazing, uPVC, Aluminium, U-values, SHGC 7Aug 11, 2017 1:47 pm Cdawn Is Low-E worth it as we have to have Low-E on our two sliding doors which are 3.6m long. (To meet 6 Star Rating). They have mixed Double glazing with Low-E to meet target. Edit: The Sliding doors are west facing. It is my honest opinion that low-E on its own is no substitute for plain double glazing. Reason is low-E works on radiant heat, and double glazing works on conducted heat. By far the majority of heat loss is through conduction. Low-E's biggest advantage is in reducing the solar heat gain coming into the home. But if the doors were facing North, then maybe it will help stop oveheating. Facing West, I would have double glazing. You will need to check with the energy rater if that would be enough, I am sure it will. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Low-E, Double Glazing, uPVC, Aluminium, U-values, SHGC 8Aug 11, 2017 1:49 pm ECOECO Cdawn Is Low-E worth it as we have to have Low-E on our two sliding doors which are 3.6m long. (To meet 6 Star Rating). They have mixed Double glazing with Low-E to meet target. Edit: The Sliding doors are west facing. It is my honest opinion that low-E on its own is no substitute for plain double glazing. Reason is low-E works on radiant heat, and double glazing works on conducted heat. By far the majority of heat loss is through conduction. Low-E's biggest advantage is in reducing the solar heat gain coming into the home. But if the doors were facing North, then maybe it will help stop oveheating. Facing West, I would have double glazing. You will need to check with the energy rater if that would be enough, I am sure it will. Thank you Re: Low-E, Double Glazing, uPVC, Aluminium, U-values, SHGC 9Aug 12, 2017 7:28 am Hi Ed, I can't find this config rated on the Wers website. Is there a way to work out the uW, SHGC? 1. Dowell thermaline 6.38mmCP Clear/14mm_argon/4mmClear (West 3.6m XOOX) That, plus below 2 glazing upgrades were not included the Nathers assessment, which defaulted to standard single glazed aluminum with uW:6.7 and SHGC:0.7. 2. Stacker 6.38CP (North 3.6m XOO) 3. Stacker 6.38CP (South 3.6m XOO) Would the above 3 make any improvement to our nathers rating? Thank you in advance! Re: Low-E, Double Glazing, uPVC, Aluminium, U-values, SHGC 10Aug 12, 2017 1:13 pm ehhc Hi Ed, I can't find this config rated on the Wers website. Is there a way to work out the uW, SHGC? 1. Dowell thermaline 6.38mmCP Clear/14mm_argon/4mmClear (West 3.6m XOOX) That, plus below 2 glazing upgrades were not included the Nathers assessment, which defaulted to standard single glazed aluminum with uW:6.7 and SHGC:0.7. 2. Stacker 6.38CP (North 3.6m XOO) 3. Stacker 6.38CP (South 3.6m XOO) Would the above 3 make any improvement to our nathers rating? Thank you in advance! Hi I don't see any comfortplus in the Thermaline range. I don't know what this was replacing, so can't comment on improvement. Converting from single glazed to low-E shows as a significant improvement in WERS, but I think it is more in the numbers than reality. Thanks Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Low-E, Double Glazing, uPVC, Aluminium, U-values, SHGC 12Aug 12, 2017 2:41 pm Welcome. Not if it must be butt glazed. Is it out of the question to put a stud in the corner and have double glazed windows? Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Low-E, Double Glazing, uPVC, Aluminium, U-values, SHGC 14Aug 12, 2017 3:03 pm I assume you want to stop the solar heat gain (?), if so then you could put a corner louvre panel over the window at 90 deg. Depth say 1m. IYKWIM. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 7731 This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19255 I don't know them all, the first 2 top of your list are best known. Rylock is a good company, Stegbar is for sale. 4 16240 |
