Browse Forums Building A New House Re: soil removal from scrape 2Aug 10, 2017 12:01 pm It is usually done on a per tonne rate, so it really depends how much there is. it will be a bit heavier when wet too so depends on the soil type and if it is dry or not. we got ours done at $15 p/t but rates varied wildly up to around $35 p/t Building a Fairmont Custom in Seaford Meadows Our Build Thread PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10242 DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6330 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6709 |
