Browse Forums Building A New House 1 Aug 07, 2017 8:17 pm We are currently trying to decide on a builder. We got quotes from several different builders and Mimosa homes site costs seem to be much below the ones of other builders at $10,000. Does anyone have experience with Mimosa homes and if their site costs are really fixed at $10,000? We don't want to sign a contract and then have unexpected costs later on. Re: Mimosa Homes Site Cost 3Mar 20, 2018 9:53 am they are not fixed if your estate does not provide level 1 compaction report. See your contract Re: Mimosa Homes Site Cost 4Mar 20, 2018 10:21 am Site costs can vary widely between builders. You need to compare all the costs when building your house. Look at the full quote for everything in your house and then make a decision which builder to go with. Re: Mimosa Homes Site Cost 6Aug 29, 2021 8:50 pm yasir_fnd is correct. I had this problem with Mimosa. When they took my deposit, it was NOT clearly explained about the level 1 compaction report. The hidden thing here is level 1 compaction report would not be provided by the land developer if they do not have any fill on your block of land. when the builders do their soil tests, there is a chance that it would come up with slight difference which then voids your fixed site costs to the advantage of the builder. They kept me holding to confirm my site costs on the same point for months and had to escalate it to the manager to finally be able to confirm it. By the time they confirmed it only because I had escaled, I lost my 25K grant. If you decide to go with them, I strongly recommend, you have it in writing. Now, I've moved away from Mimosa losing my deposit of 2K and building with other builder for peace of mind to also avoid structural issues mentioned in productreviews.com. My colleagues friends 9 families collectively wanted to build through mimosa have also moved away from them. Re: Mimosa Homes Site Cost 7Aug 29, 2021 9:03 pm Annunox yasir_fnd is correct. I had this problem with Mimosa. When they took my deposit, it was NOT clearly explained about the level 1 compaction report. The hidden thing here is level 1 compaction report would not be provided by the land developer if they do not have any fill on your block of land. when the builders do their soil tests, there is a chance that it would come up with slight difference which then voids your fixed site costs to the advantage of the builder. They kept me holding to confirm my site costs on the same point for months and had to escalate it to the manager to finally be able to confirm it. By the time they confirmed it only because I had escaled, I lost my 25K grant. If you decide to go with them, I strongly recommend, you have it in writing. Now, I've moved away from Mimosa losing my deposit of 2K and building with other builder for peace of mind to also avoid structural issues mentioned in productreviews.com. My colleagues friends 9 families collectively wanted to build through mimosa have also moved away from them. Hi Annunox, How much was the site cost did Mimosa quote you at the end before you moved to a different builder? How much was your fixed site cost at the preliminary quote? I am considering signing a contract with Mimosa, so your insights into this would be highly appreciated. Regards We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37142 Thanks for the insight! My plot is a new development so hopefully I won't have too much problem during build as everyone should be roughly building together. I also… 2 3372 Approvals are covered in the cost we are paying to the pool company. The only thing stated in our home build contract for the additional cost is engineering support. … 3 7119 |
