Browse Forums Building A New House 1 Aug 24, 2008 5:25 pm Hi All,
I'll be having a 1 year Maintenance Inspection soon. Right now there are a lot of hairline cracks on the grout , garage floor, edges on window and door frames and skirting. Some are actually quite bad. I'm just wondering whether the builder would fix it or treat this as normal due to a new building. If you could share your experience that would be helpful.. Cheers.. Re: What to expect on Maintenance Inspection 2Aug 25, 2008 6:31 pm The only thing I am aware of with his inspection that the builder will fix is if the crack is as big as the size of a credit card thickness.
My english is shocking...... If the crack is the same thickness as a credit card it is deemed to be a builder issue. They have a special tool that they use to decide. Thats been my experience anyway. You should have a form that they would have left with you to write down anything of concern, make sure you include anything you think might just need servicing like garage doors,ovens, air con etc, they should all be free within the warranty period. Most of these are within a year though. Sometimes the company gives you a grace period.............. i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98688 you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5346 Hi, I have this sewer inspection point sitting in an odd spot in the rear of my yard: https://imgur.com/ghLI98q What I'd like to do is put a firepit in that corner of… 0 6525 |
