Browse Forums Building A New House 1 Jul 29, 2017 11:29 am Hi everyone Wondering what you did with the soil removal of the scraping and what it costed? Did ypu let the builder remove it? If yes how much did the costs go up for the initial soil removal? If no whats the price charged to get it removed? Trying to work out which will be best for us Tia Re: Soil removal from scrape 3Jul 29, 2017 5:34 pm Do you mean when they do the site scrape at the start of the construction? We haven't started yet, I just assumed they would get rid of it? Do they just leave it in a pile on your block? Re: Soil removal from scrape 4Jul 29, 2017 7:01 pm Yes. Apparently its not part/classedunder the soil removal from footings ands its left to the side to get rid off because of the grass / weed bits in it. Its for owner to get rid off before construction start Re: Soil removal from scrape 5Jul 29, 2017 7:08 pm They say if its Added to other soil fir removal all the soil is removed at an higher rate due to it hVing grass /vegetaty bits. Apparently a common thing with building. We had no idea till we got variations from soil report send to us with a faq pAge stating the small details Re: Soil removal from scrape 6Jul 29, 2017 7:18 pm Interesting, it's never been mentioned to us, we hope to start building soon. Our block was scraped and bare but now due to delays it has grass. Re: Soil removal from scrape 7Jul 29, 2017 7:24 pm Oh no! We did not had it mentioned at all... just when i saw it in the soil report info faq's.i asked and was told oh yes if you dont remove we can but will put up the cost of the other doil to be removed too.and with a side note if its not temoved quickly we will and pass on the fees Re: Soil removal from scrape 8Jul 29, 2017 8:03 pm Where in your contract was that information? Who are you building With? Soil removal from scrape 11Jul 30, 2017 12:31 pm This is tricky. Builder will remove soil, break rocks, and remove rocks if you have fixed the site costs. When site cost is fixed, builder will put in prohibitive amount of provisions to do all those work and you won't get unused portion of the provision back. You should fix the site cost only if you think you will hit rocks the size of shopping trolley. They cost 1k-3k to break and remove. If you don't fix the site cost, then somewhere in the contract or variation will say that removing excess soil, breaking rock, removing rock is at owners cost plus builder margin. For me, this was stated on page 1 of contract with M. Even if you have a level slope, assume some soil needs to be removed because plumbing for stormwater, sewerage, and water always produces about 1m of excess soil. NabeelC | Metricon Merricks 38 | https://forum.homeone.com.au/viewtopic.php?f=31&t=86276 Re: Soil removal from scrape 16Jul 30, 2017 2:15 pm i beleive i am with same builder as OP I was led to believe the quoted soil removal was for all soil by the sales agent - of course that discussion was back in mid march so cant recall the actual wording used but again nothing in writing to show that effect build contract states the following (standard MBA contract i beleive) - think these are the relevant bits Completion - surplus soil is owners responsibility unless otherwise specified Site Preparation - to levels as per attached site plan and engineers report - takes 2-3 months from signing to get these excavations - the site covered by the building and at least 1000mm wide around teh excavation or to the boundary of site shall be cleared and/or graded as per the site plan. excavations for all footings shall be as per engineers recommendations also has a bit about any abnormal or hidden conditions encountered are at the owners expense. Contract then lists surplus soil removal as a PC item - estimate only - however once engineering report is received variation received fixing the surplus soil removal costs but that variation excludes the surface scrape soil as per the text provided by the OP above. I suppose if their soil removal estimates was for all the soil then they wouldn't be able to use the low list prices that they use not realising this myself i consider to be a failure of my pre contract signing research Re: Soil removal from scrape 17Jul 30, 2017 4:02 pm Agent basically said they scrape we have to pay and get some one to remove soil or they do nut all soil is removed at an higher rate. Said its not in contract cause it a given and generally accepted by all builders. Maintaining the lot will not affect the removal of soil either way you pay and get it done self or pay them. Disappointed and feel desieved with this. Re: Soil removal from scrape 18Jul 30, 2017 4:11 pm I know the feeling and unfortunately its a unknown potential cost that just like you guys i have come to realise im just going to have to find the money for when it comes time to remove it. Waiting on a couple of estimates but its a huge unknown and that sucks. Still should be made aware of it up front IMO instead of assuming people are aware of it and will include it in their estimates Re: Soil removal from scrape 20Jul 30, 2017 5:21 pm Spoke with a friend today who used to be a building inspector and has built twice himself plus supervised a couple of builds for friends / family. He laughed and said its something that really should be made clear at the start. So maybe its a per builder thing he dud recommend i go with a particular builder but i didnt really pick his brain as much as i should have - both had other stuff going on at that time PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10256 DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6337 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6713 |
