Browse Forums Building A New House 1 Jul 25, 2017 7:51 pm Looking for some opinions as to which house to build on our lot. We have quotes from MJH and M and like both houses. It's so difficult to decide on one. Both houses have pros and cons and we're stuck! We keep going back and forth between the two. MJH - Havana28 love this house and the plan. We're getting quality fixtures/appliances, steel frame, hebel, large alfresco grande and Actron A/C but the house is 25sq including the large alfresco, so the living area is not that big. We don't use the alfresco in our current house that much, so not sure if we'll make use of the one in the new build. I don't know - we might given than it's large and we can have a nice outdoor BBQ/kitchen in there. M - Mantra28 we like this house/plan too and it's 28sq and wider than the havana, AND we can also get it for the same price as Havana. Flooring is included as well. Quality won't be as good as MJH from what I have seen in the displays but still great value. What would you do? Go for the larger house or take the smaller house with quality fittings? This won't be our forever home, so need to think about future/reselling value. Would have added a poll if I knew how to as we're deadlocked and need to decide soon.... Floor plans below - Mantra on left, Havana on right Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Please help - MJH or M?? 4Jul 26, 2017 7:42 am hunter_home Make up a spreadsheet and compare include House area, walls lengths, tiling' floor covering areas,fittings, Builders make it difficult to compare one house with another BTW, please check & see if you get exactly what's in the display..usually it's the standard builders range? From a Construction Engineering viewpoint, I would choose Timber Frame & Brick over steel Frame & Hebel Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Please help - MJH or M?? 5Jul 26, 2017 10:08 am StructuralBIMGuy @hunter_home Make up a spreadsheet and compare include House area, walls lengths, tiling' floor covering areas,fittings, Builders make it difficult to compare one house with another BTW, please check & see if you get exactly what's in the display..usually it's the standard builders range? From a Construction Engineering viewpoint, I would choose Timber Frame & Brick over steel Frame & Hebel Thanks StructuralBIMGuy. We started making a spreadsheet, but it just confused us even more and we left it there incomplete We checked what's included and it's all standard builders range. We were offered packs/offers with upgrade options and have taken up some of them. Can I ask why you would recommend Timber and brick over steel and Hebel? We thought getting a steel frame would be a plus as we don't have to worry about termite protection every year and it's much stronger if I understand correctly? We had never heard of Hebel before going to the builders and they said it's better insulation and would look nice as it'll all be rendered. Having a corner lot, we though it might be nice to have the rendered Hebel look. Re: Please help - MJH or M?? 7Jul 26, 2017 1:39 pm Agreed. The MJH. You don't seem to gain anything from the extra 3 squares in the Metricon. The only advantage to the Metricon one would be if your backyard faces north. Building Monte Carlo 40- Wisdom homes Building Monte Carlo 40- Wisdom homes Re: Please help - MJH or M?? 8Jul 26, 2017 6:51 pm Hunter_home I forgot to ask 1. Is it a truss roof or Pitched Coupled roof (Timber rafters)? 2. Are you in a coast zone subject to corrosion? Steel trusses and Autoclave Aerated bricks have a long history of failures here in WA Steel trusses with thermal expansion and gyprock cracking Autoclave Aerated bricks with structural cracking Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Please help - MJH or M?? 9Jul 27, 2017 11:33 am StructuralBIMGuy @Hunter_home I forgot to ask 1. Is it a truss roof or Pitched Coupled roof (Timber rafters)? 2. Are you in a coast zone subject to corrosion? Steel trusses and Autoclave Aerated bricks have a long history of failures here in WA Steel trusses with thermal expansion and gyprock cracking Autoclave Aerated bricks with structural cracking Hi, 1. This is the link for their steel frame brochure (Supaloc made from Truecore steel). We get 26' roof pitch and it's a steel truss. http://www.mcdonaldjoneshomes.com.au/si ... lowres.pdf 2. We're not in a coast zone Thanks Re: Please help - MJH or M?? 10Jul 27, 2017 12:58 pm hunter_home you can ask for extended warranties and engineering solutions that preclude the above. As an engineer that does structural repairs..I just don't see them in the first instance? Whereby, later maintenance & repairs become very expensive or impossible I am simply highlighting problems that do exist. you need to make informed decisions that are based on facts, data and not media personality endorsements. HTH Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Please help - MJH or M?? 11Jul 28, 2017 8:17 pm StructuralBIMGuy @hunter_home you can ask for extended warranties and engineering solutions that preclude the above. As an engineer that does structural repairs..I just don't see them in the first instance? Whereby, later maintenance & repairs become very expensive or impossible I am simply highlighting problems that do exist. you need to make informed decisions that are based on facts, data and not media personality endorsements. HTH StructuralBIMGuy, many thanks for this. Will ask them about extended warranties and other issues you've highlighted. Do you have any advice on using Hebel? Re: Please help - MJH or M?? 12Jul 29, 2017 9:47 am hunter_home I suggest you discuss this with a Structural Engineer Hebel tech manual and also get them to design & supervise the hebel blockwork as well Most West Australians Won't have a bar of Autoclaved Aerated Bricks a case of once bitten (before) twice shy. Here are some tips on selecting building materials 1. Display homes look great when new..Builders flip them in a couple of years, for obvious reasons 2.Check out ex display homes after say 10-20 years... you'll see what I mean 3. If you are building in severe environments ie coastal, industrial etc, always consider durability 4.The cutting edge in new material engineering is sometimes the bleeding edge 5. There are reasons why we still use traditional building materials, namely they have withstood the test of time goodluck Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7157 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12759 All 3 items listed are defects and are of concern. Please seek qualified independent inspector and/or legal advice for your state. 1 8211 |
