Browse Forums Building A New House 1 Jul 20, 2017 2:27 pm Hi thank you for taking the time to read my possibly silly question I didn't want to big the supervisor if this was normal Is it normal to have the meter/electrical box in the wall like that I had some odd feeling it would be outside on the brick not in the wall it stops us hanging wall lamps next to the bed Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is 100% true. You can not hang anything on steel frames. very frustrating 8 8030 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28814 |
