Browse Forums Building A New House Re: Building a new house and doing the flooring myself what' 7Oct 21, 2019 7:34 am Norfolk Suggest checking your slab is level per your proposed flooring installation specs, and at a minimum to Australian standards. Otherwise you will incur the additional costs to make it level. 0 2021 The DIY project can be broken into two major steps. Planning and Design and Construction. Both of these steps are as important as one another to ensure you give… 0 5175 Hi group, have some damage to the door frame and skirting board. It's a side door to the laundry area. Only has a security door. I had a termite inspection (note drill… 0 5059 |
