Building a new house and doing the flooring myself what's th
I'm building a new house with Domaine Homes but I opted out of the comfort pack as we want to do timber flooring. Have you done that before? What's your experience?
Hi, I am looking at doing the same. Did you end up doing your own flooring after handover? If so, was it a good experience? Who did you use for flooring?
The only issue thus far has been the skirting. We agreed with builder to not install skirting, but in they argued that they could not just leave the skirting sitting around and installed it anyway. This will now have to be removed (carefully) after handover.
I used Floor Gallery in Castle Hill. They removed the skirting, there’s some rework you have to do but not much. I’m happy so far.
Thanks for replying. Good to hear that you’re happy doing it that way, I’ll check out Floor Gallery.
Suggest checking your slab is level per your proposed flooring installation specs, and at a minimum to Australian standards. Otherwise you will incur the additional costs to make it level.
Anyone using Bellriver bulder and doing the turnkey projects
30/06/2023
The DIY project can be broken into two major steps. Planning and Design and Construction. Both of these steps are as important as one another to ensure you give…
30/08/2023
Hi group, have some damage to the door frame and skirting board. It's a side door to the laundry area. Only has a security door. I had a termite inspection (note drill…
