Browse Forums Building A New House Re: First Timer (Built By Momu @ Calleya) 282Mar 10, 2018 7:55 pm Find my build thread here: https://forum.homeone.com.au/viewtopic.php?t=88694&f=31&p=1729530#p1729530 Re: First Timer (Built By Momu @ Calleya) 284Mar 10, 2018 8:07 pm Find my build thread here: https://forum.homeone.com.au/viewtopic.php?t=88694&f=31&p=1729530#p1729530 Re: First Timer (Built By Momu @ Calleya) 285Mar 11, 2018 9:14 pm Find my build thread here: https://forum.homeone.com.au/viewtopic.php?t=88694&f=31&p=1729530#p1729530 Re: First Timer (Built By Momu @ Calleya) 287Mar 12, 2018 9:27 pm Find my build thread here: https://forum.homeone.com.au/viewtopic.php?t=88694&f=31&p=1729530#p1729530 Re: First Timer (Built By Momu @ Calleya) 289Mar 12, 2018 11:27 pm my new build thread- Ben Trager https://forum.homeone.com.au/viewtopic.php?f=31&t=89826 my switch build thread (2011) https://forum.homeone.com.au/viewtopic.php?f=31&t=36569 Re: First Timer (Built By Momu @ Calleya) 290Mar 13, 2018 10:16 pm Find my build thread here: https://forum.homeone.com.au/viewtopic.php?t=88694&f=31&p=1729530#p1729530 Re: First Timer (Built By Momu @ Calleya) 291Mar 14, 2018 12:41 am my new build thread- Ben Trager https://forum.homeone.com.au/viewtopic.php?f=31&t=89826 my switch build thread (2011) https://forum.homeone.com.au/viewtopic.php?f=31&t=36569 Re: First Timer (Built By Momu @ Calleya) 292Mar 14, 2018 10:10 am Find my build thread here: https://forum.homeone.com.au/viewtopic.php?t=88694&f=31&p=1729530#p1729530 Re: First Timer (Built By Momu @ Calleya) 293Mar 15, 2018 10:42 pm Find my build thread here: https://forum.homeone.com.au/viewtopic.php?t=88694&f=31&p=1729530#p1729530 Re: First Timer (Built By Momu @ Calleya) 294Mar 16, 2018 10:32 pm Find my build thread here: https://forum.homeone.com.au/viewtopic.php?t=88694&f=31&p=1729530#p1729530 Re: First Timer (Built By Momu @ Calleya) 295Mar 18, 2018 8:28 am Day 8 consisted of the driveway being poured over the course of the morning. Concrete rocked up an hour late so that was a pain, however the colour is looking good. We got a bit more of the flooring down however it has taken much longer as there as so many cuts required in the Kitchen the door frames are proving to be quite tricky and tedious but we are slowly getting there. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Find my build thread here: https://forum.homeone.com.au/viewtopic.php?t=88694&f=31&p=1729530#p1729530 Re: First Timer (Built By Momu @ Calleya) 296Mar 18, 2018 9:28 am We removed a lot of the cutting in/out from our kitchen design to suit flooring and quad. We have heard that some installers cut the door frames so that the flooring slides underneath rather than cutting around, eek.... Steady progress has its rewards, you get things done your way. Re: First Timer (Built By Momu @ Calleya) 297Mar 18, 2018 11:32 am Day 8 and lots of work completed I see, Looking great! Where did you source your flooring from? great choice in colour! _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 Re: First Timer (Built By Momu @ Calleya) 298Mar 18, 2018 8:38 pm sparky_JsP Day 8 and lots of work completed I see, Looking great! Where did you source your flooring from? great choice in colour! Thanks mate! I dealt with 'Carpets and Floors at Yours' as they were a small local business around the corner from our house. Great to deal with and good pricing too. Also held our floor stock for us until we got our keys, so that was really nice of them. Find my build thread here: https://forum.homeone.com.au/viewtopic.php?t=88694&f=31&p=1729530#p1729530 Re: First Timer (Built By Momu @ Calleya) 299Mar 18, 2018 8:42 pm Day 9 and our last day off before going back to work. The driveway got washed back, exposing the beautiful stones. I'll swing past after work tomorrow and seal it which will slightly change the colour. Finished the Theatre flooring too and we are very happy we decided to continue the vinyl through as it makes the rooms feel more connected and larger. Next weekend we will be back to finish the flooring in the hallways and our bedroom, install the skirting and then build our robe fitout. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Find my build thread here: https://forum.homeone.com.au/viewtopic.php?t=88694&f=31&p=1729530#p1729530 Re: First Timer (Built By Momu @ Calleya) 300Mar 18, 2018 9:47 pm Flooring is gorgeous! Is it vinyl or laminate? Driveway looks great too. You’ve done so much in a short time! my new build thread- Ben Trager https://forum.homeone.com.au/viewtopic.php?f=31&t=89826 my switch build thread (2011) https://forum.homeone.com.au/viewtopic.php?f=31&t=36569 DIY, Home Maintenance & Repair We purchased a 1960s property that is on timber stumps mostly, and a newer section is on concrete stumps. We had a building inspection initially and they reported some… 0 12709 Strong enough for what? For linen, absolutely. To climb on, no. I've got similar shelving in my garage and it holds a decent amount of weight. 900 wide shelves will carry… 1 4166 Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused. 6 4856 |
