Browse Forums Building A New House Re: First jome build SA Hickinbotham 161Sep 11, 2017 12:36 pm Released for construction It can start anytime from now till 4 weeks from now depending on trades available We do however need to remove boundary fence fir our garage to be build and dlab pour for garage Can anyone give us more info on this? Can we leave the poles in ir do we remove everything? tia @enthilza any news on when they will start in your building Re: First jome build SA Hickinbotham 162Sep 11, 2017 1:11 pm no update but planning on going for a drive out there again wednesday i would assume the entire fence along the boundary wall needs to be removed and temporary fencing erected - have you discussed the fencing with your neighbors to see their preference in handling this - might be able to just relocate these panels to use as temporary fencing for the moment assuming your building on the boundary the garage wall will replace that fence and those posts - if neighbors are asking you to contribute to fencing costs and these are no longer needed once your garage wall is built but can be matched across the back you should see if you can use the fencing along your back - thinking you said only had fencing on the 2 sides Re: First jome build SA Hickinbotham 163Sep 11, 2017 1:19 pm We have fences on all sides builder only said fence remove size of garage plus an extra meter but no ither info as to if we should remove poles too cause the neighbours have a gate that use a pole and if we remove pole it wint close. The neighbours said to do what's easier for us with vlosing up till after construction but they have small dogs so we need to close it up between wall and fence So looking for options to remove fence and poles and vlise up gap till construction is finished Wondering if we could just cut off the poles to the soil level (specifications we really need to make sure done correctly/do we dig out the poles with their concrete Re: First jome build SA Hickinbotham 164Sep 11, 2017 1:37 pm can you use the existing fence and gate to close of from the fence that is remaining to the neighbors wall. that still encloses their year yard that way for their dogs, then once your wall is up you should be able to move it back to the correct location and anchor it against your garage wall. pretty sure your garage wall foundations will be in the same location as those poles and if concrete from poles is there i am sure they will charge for its removal Re: First jome build SA Hickinbotham 165Sep 11, 2017 1:41 pm Was thinking that but the curreng gate is attached to poles thats concreted into the ground so we wont be able to use thaf one and the panels is round 2m wide we need to fill a 1m gap lol will try to anchor it between windowsill/down pipe and tie to current fence just worried how we will go about with the pold from the existing gate that we have to remove will maybe get a couple of quotes and see what options we get Re: First jome build SA Hickinbotham 166Sep 13, 2017 12:10 am Hi Lovisa great journey so far was a good read ! my build will be starting in the next month or so aswell so will be interesting to see how our progress compares !! Re: First jome build SA Hickinbotham 175Sep 13, 2017 5:08 pm yay for a portapotty!! things are really starting up now. hope the quote for the fencing isn't too bad Re: First jome build SA Hickinbotham 176Sep 15, 2017 8:55 pm Woohoo they started with our trenches today can now more or less see our house size and yard size Tomorrow we will get a quote on fence removal and have it removed sunday/monday Then we will buy some temporary fences at bunings and put it up for our neighbours:) Re: First jome build SA Hickinbotham 178Sep 18, 2017 9:40 am sewer lines then the plastic damp proof stuff then the reinforcement then slab i think the house across from me that they was scraping and trenching for last week looked ready for slab pour when i was at my block on the weekend so doesn't take to long So it looks like we finally have some movement on site! Definitely later than expected, but I'll take any progress at this point. I'll drop by over the weekend to get… 5 26967 hi guys. Please be nice. First time home builder in Qld. I would like some feedback please on whether I should build my granny flat first before my main house at the… 0 4584 Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 17507 |
