Browse Forums Building A New House 1 Jul 07, 2017 5:55 pm Hello, We have just had our plumbing and slab laid. On inspecting the site a few days ago, we noticed a pink pipe that had been placed in the backyard that wasn't on any of the drawings. We will be putting an inground pool into that space as soon as we get the keys, so I'm a little worried about this pipe. On asking the builder what it is, they said: "it appears that this pipe does form part of the sewer and is most likely inspection opening which will need to remain onsite. At this stage, we are unable to have that removed and will need to remain." Our site plan clearly shows an easement of 1.8m from the back fence. This pipe however, is 4 m from the back fence line, well outside the easement. It does not exist in any of our drawings. We have asked them again if they can relocate this pipe and are awaiting their answer, which I fear may be a flat "NO". Can someone please tell me what an inspection opening is and if you think it can be relocated or a pool built over it? I have attached a pic of the dreaded pipe! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Unexpected Sewerage Pipe ruining pool plans- Advice Plea 2Jul 07, 2017 6:55 pm My sister had this issue but as they had supplied a landscaping plan with the pool. They were able to get it moved. 2nd build here we come in Whittlesea! https://forum.homeone.com.au/viewtopic.php?f=31&t=92617 1st Build - Henley - Cooper in Doreen! (2009) https://forum.homeone.com.au/viewtopic.php?f=31&t=17354 Re: Unexpected Sewerage Pipe ruining pool plans- Advice Plea 3Jul 07, 2017 11:32 pm ayaman It sounds like you didn't have an exclusion zone on your drawings. They might be able to move it but they will probably charge you for it. Worst case, you can also get the pool builder plumbers to relocate it for you. Or get a local plumber to do that for you after handover. Building the Madison 40 | By Porter Davis Re: Unexpected Sewerage Pipe ruining pool plans- Advice Plea 4Jul 07, 2017 11:36 pm Gio @ayaman It sounds like you didn't have an exclusion zone on your drawings. They might be able to move it but they will probably charge you for it. Worst case, you can also get the pool builder plumbers to relocate it for you. Or get a local plumber to do that for you after handover. Thanks Gio, at least there might be some options we can work with there. What is an exclusion zone? Re: Unexpected Sewerage Pipe ruining pool plans- Advice Plea 5Jul 08, 2017 12:18 am An exclusion zone is basically an area in the backyard where you don't want pipe running so that you can put in a pool/spa later. Pipes just run around the pool area not through it. Building the Madison 40 | By Porter Davis Re: Unexpected Sewerage Pipe ruining pool plans- Advice Plea 6Jul 08, 2017 10:07 am Gio An exclusion zone is basically an area in the backyard where you don't want pipe running so that you can put in a pool/spa later. Pipes just run around the pool area not through it. Ahhh yes. That makes sense. No we didn't think to indicate an exclusion zone.... wish we had though! yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7326 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4872 I think you are getting different numbers because they all just based them on "other jobs" even though each job is unique. Often, with builders, unless you're speaking to… 3 3241 |
