Browse Forums Building A New House Re: Building with Metricon - Liberty 45 - NSW 21Nov 06, 2017 2:08 am I think I would have liked the dinning 3.5 meters in width. 1. May be too late but go for 42 sq liberty it it suits the block better ( sales should have known then FSR LIMITIONS PRIOR. 2. In know 45 has a massive master bedroom so alternative for me would have been extending the alfresco be another meter out by the whole width of your house and put another stacker door in the dinning area to combat this short fall. The cost may be $1000 per square meter to extend the alfresco and the stacker door another $3k . It’s ok as it is now though. Re: Building with Metricon - Liberty 45 - NSW 22Nov 06, 2017 5:39 am Mojitostan I think I would have liked the dinning 3.5 meters in width. 1. May be too late but go for 42 sq liberty it it suits the block better ( sales should have known then FSR LIMITIONS PRIOR. 2. In know 45 has a massive master bedroom so alternative for me would have been extending the alfresco be another meter out by the whole width of your house and put another stacker door in the dinning area to combat this short fall. The cost may be $1000 per square meter to extend the alfresco and the stacker door another $3k . It’s ok as it is now though. Re: Building with Metricon - Liberty 45 - NSW 23Nov 06, 2017 9:05 am At the moment, the space in front of island is a big waste. The narrow dining is out of proportion. You can consider to rotate the island to face dining, reconfigure the kitchen layout, that way gives you more depth in dining. Re: Building with Metricon - Liberty 45 - NSW 24Nov 06, 2017 9:35 am Mojitostan I think I would have liked the dinning 3.5 meters in width. 1. May be too late but go for 42 sq liberty it it suits the block better ( sales should have known then FSR LIMITIONS PRIOR. 2. In know 45 has a massive master bedroom so alternative for me would have been extending the alfresco be another meter out by the whole width of your house and put another stacker door in the dinning area to combat this short fall. The cost may be $1000 per square meter to extend the alfresco and the stacker door another $3k . It’s ok as it is now though. Re: Building with Metricon - Liberty 45 - NSW 25Nov 06, 2017 9:38 am Passi Mojitostan I think I would have liked the dinning 3.5 meters in width. 1. May be too late but go for 42 sq liberty it it suits the block better ( sales should have known then FSR LIMITIONS PRIOR. 2. In know 45 has a massive master bedroom so alternative for me would have been extending the alfresco be another meter out by the whole width of your house and put another stacker door in the dinning area to combat this short fall. The cost may be $1000 per square meter to extend the alfresco and the stacker door another $3k . It’s ok as it is now though. Re: Building with Metricon - Liberty 45 - NSW 26Nov 06, 2017 9:53 am LibertyNR At the moment, the space in front of island is a big waste. The narrow dining is out of proportion. You can consider to rotate the island to face dining, reconfigure the kitchen layout, that way gives you more depth in dining. Re: Building with Metricon - Liberty 45 - NSW 27Nov 06, 2017 10:12 am dfin LibertyNR At the moment, the space in front of island is a big waste. The narrow dining is out of proportion. You can consider to rotate the island to face dining, reconfigure the kitchen layout, that way gives you more depth in dining. We are building liberty40, very similar layout with island facing back, I don’t have any issue with that as you are looking towards the backyard when washing. Of course you need wife’s permission. Personally I think having a good sized dining is way more important, it’s just personal opinion, good luck! Re: Building with Metricon - Liberty 45 - NSW 28Nov 06, 2017 11:04 am dfin Hi All, Also want some inputs on an issue with the dinning area. Bcause the floor ratio limitation, we have to reduce the size of the dinning area. Now the depth of it is only about 2.3 meters, will this be a problem. Did not actually think it through previously. Is there any suggestion on the kitchen/dinning floor plan change to mitigate it? Thanks a lot! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ As mentioned above by LibertyNR, rotating the bench will probably fix your issue. Here's the Metricon Vantage layout, there's also a few other designs they have that also follow that layout. So it's more common than you think =) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Metricon - Liberty 45 - NSW 29Nov 06, 2017 11:19 am LibertyNR dfin LibertyNR At the moment, the space in front of island is a big waste. The narrow dining is out of proportion. You can consider to rotate the island to face dining, reconfigure the kitchen layout, that way gives you more depth in dining. We are building liberty40, very similar layout with island facing back, I don’t have any issue with that as you are looking towards the backyard when washing. Of course you need wife’s permission. Personally I think having a good sized dining is way more important, it’s just personal opinion, good luck! Re: Building with Metricon - Liberty 45 - NSW 30Nov 06, 2017 11:23 am dulie dfin Hi All, Also want some inputs on an issue with the dinning area. Bcause the floor ratio limitation, we have to reduce the size of the dinning area. Now the depth of it is only about 2.3 meters, will this be a problem. Did not actually think it through previously. Is there any suggestion on the kitchen/dinning floor plan change to mitigate it? Thanks a lot! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ As mentioned above by LibertyNR, rotating the bench will probably fix your issue. Here's the Metricon Vantage layout, there's also a few other designs they have that also follow that layout. So it's more common than you think =) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks very much for all your kind help, made me encouraged for the journey to come! Re: Building with Metricon - Liberty 45 - NSW 31Nov 06, 2017 12:09 pm dfin dulie dfin Hi All, Also want some inputs on an issue with the dinning area. Bcause the floor ratio limitation, we have to reduce the size of the dinning area. Now the depth of it is only about 2.3 meters, will this be a problem. Did not actually think it through previously. Is there any suggestion on the kitchen/dinning floor plan change to mitigate it? Thanks a lot! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ As mentioned above by LibertyNR, rotating the bench will probably fix your issue. Here's the Metricon Vantage layout, there's also a few other designs they have that also follow that layout. So it's more common than you think =) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Another finding made me feel much better now. Was quite upset last night for having not noticed and fixed this issue early. Thanks very much for all your kind help, made me encouraged for the journey to come! Glad that you have a happy wife now. In fact, it you are willing to cut the walk in linen back 600, you are going to have bigger kitchen, would be nice. Have you considered to add a sliding door between kitchen and laundry, we did, we thought it would be handy to look after washings when cooking, and taking out the rubbish from kitchen too. And the hot water unit could be on the other side for kitchen and bathroom to have quicker access Re: Building with Metricon - Liberty 45 - NSW 32Nov 06, 2017 1:59 pm LibertyNR dfin dulie [quote="dfin"]Hi All, Also want some inputs on an issue with the dinning area. Bcause the floor ratio limitation, we have to reduce the size of the dinning area. Now the depth of it is only about 2.3 meters, will this be a problem. Did not actually think it through previously. Is there any suggestion on the kitchen/dinning floor plan change to mitigate it? Thanks a lot! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ As mentioned above by LibertyNR, rotating the bench will probably fix your issue. Here's the Metricon Vantage layout, there's also a few other designs they have that also follow that layout. So it's more common than you think =) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Another finding made me feel much better now. Was quite upset last night for having not noticed and fixed this issue early. Thanks very much for all your kind help, made me encouraged for the journey to come! Glad that you have a happy wife now. In fact, it you are willing to cut the walk in linen back 600, you are going to have bigger kitchen, would be nice. Have you considered to add a sliding door between kitchen and laundry, we did, we thought it would be handy to look after washings when cooking, and taking out the rubbish from kitchen too. And the hot water unit could be on the other side for kitchen and bathroom to have quicker access [/quote]Now I am thinking whether should pass this to the wife or not, she will definitely go for it Not sure why metricon put the hotwater unit to the other side, I will check with them. Would you mind share your floorplan? Feels there should be lots of stuff I can learn Re: Building with Metricon - Liberty 45 - NSW 34Nov 07, 2017 2:52 pm Thanks for sharing, looks great! Only wish I had seen it earlier. Now we kind don't have much energy to change and just wish the buliding process go smoothly. Re: Building with Metricon - Liberty 45 - NSW 35Nov 07, 2017 4:00 pm Hi All, Need some suggestions on driveway allocation. Seems that I do not want to make any decision before getting insights from the homeone forum... Thanks for all your kind help. The current one is sitting right in the middle of the block, I really don't like it... Re: Building with Metricon - Liberty 45 - NSW 36Nov 08, 2017 2:05 pm dfin Hi All, Need some suggestions on driveway allocation. Seems that I do not want to make any decision before getting insights from the homeone forum... Thanks for all your kind help. The current one is sitting right in the middle of the block, I really don't like it... Omg our block and site plan almost look identical. Approx 4m gap on garage side of house. We don't know how to have the driveway either. Help! Re: Building with Metricon - Liberty 45 - NSW 37Nov 08, 2017 2:12 pm craigo dfin Hi All, Need some suggestions on driveway allocation. Seems that I do not want to make any decision before getting insights from the homeone forum... Thanks for all your kind help. The current one is sitting right in the middle of the block, I really don't like it... Omg our block and site plan almost look identical. Approx 4m gap on garage side of house. We don't know how to have the driveway either. Help! Shake hands. I am a dumb engineer, so decided to put the crossover at 1/3 of the frontage counting from the north boundary ... not sure what it will look like having built on acres several times i suggest that you also need to add the cost of a sewerage system and any associated fencing, water tanks with associated extra… 2 1465 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 11503 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8909 |
