Browse Forums Building A New House Re: Building Arden homes Votivo 37 in South East 463Aug 14, 2018 10:26 pm _________________________________________ Regards Manj https://forum.homeone.com.au/viewtopic.php?f=31&t=88256 Re: Building Arden homes Votivo 37 in South East 464Aug 14, 2018 11:47 pm follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 466Aug 15, 2018 6:17 am Build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=88062 Re: Building Arden homes Votivo 37 in South East 467Aug 17, 2018 5:39 pm So had a visit today and met SS regarding frame completion date - he showed the photos taken on 21/05/18 of work done. Have been told that PCI May be around 27/08/18 and can expect handover a week after Carpet is in Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Laundry benchtop Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Common bath Spa done and shower at 1200x1200 looks good size Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ a But the problem is regarding master ensuite BIR wherein we missed to check the height of shelf and it is glued to the plaster - so a problem here how to move it Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Then I saw this - the downlights supposed to go inside the cabinet but the electricians put it this way Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Building Arden homes Votivo 37 in South East 468Aug 18, 2018 10:18 pm pEast So had a visit today and met SS regarding frame completion date - he showed the photos taken on 21/05/18 of work done. Have been told that PCI May be around 27:05/28 and can expect handover a week after Carpet is in Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Laundry benchtop Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Common bath Spa done and shower at 1200x1200 looks good size Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ a But the problem is regarding master ensuite BIR wherein we missed to check the height of shelf and it is glued to the plaster - so a problem here how to move it Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Then I saw this - the downlights supposed to go inside the cabinet but the electricians put it this way Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey PEast, is this correct for under cabinet lighting? We have asked for the same but this is absolutely not what we asked for. I thought that they would be recessed into the cabinets? Re: Building Arden homes Votivo 37 in South East 469Aug 19, 2018 6:41 am Ezza78 pEast So had a visit today and met SS regarding frame completion date - he showed the photos taken on 21/05/18 of work done. Have been told that PCI May be around 27:05/28 and can expect handover a week after Carpet is in Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Laundry benchtop Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Common bath Spa done and shower at 1200x1200 looks good size Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ a But the problem is regarding master ensuite BIR wherein we missed to check the height of shelf and it is glued to the plaster - so a problem here how to move it Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Then I saw this - the downlights supposed to go inside the cabinet but the electricians put it this way Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey PEast, is this correct for under cabinet lighting? We have asked for the same but this is absolutely not what we asked for. I thought that they would be recessed into the cabinets? Ezza it will be corrected - I showed to my SS my contract showing false bottom in cabinet charged around 170 and also electrical drawing showing the lights r in the centre of cabinets. Will be changed now and put into cabinets follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 470Aug 19, 2018 7:23 am Ezza78 pEast So had a visit today and met SS regarding frame completion date - he showed the photos taken on 21/05/18 of work done. Have been told that PCI May be around 27:05/28 and can expect handover a week after Carpet is in Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Laundry benchtop Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Common bath Spa done and shower at 1200x1200 looks good size Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ a But the problem is regarding master ensuite BIR wherein we missed to check the height of shelf and it is glued to the plaster - so a problem here how to move it Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Then I saw this - the downlights supposed to go inside the cabinet but the electricians put it this way Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey PEast, is this correct for under cabinet lighting? We have asked for the same but this is absolutely not what we asked for. I thought that they would be recessed into the cabinets? We asked for the same as well, but can't find any reference to it being recessed anywhere on my plans or contract. Will need to confirm with my CSA. Re: Building Arden homes Votivo 37 in South East 471Aug 19, 2018 7:40 am _daz_ Ezza78 pEast So had a visit today and met SS regarding frame completion date - he showed the photos taken on 21/05/18 of work done. Have been told that PCI May be around 27:05/28 and can expect handover a week after Carpet is in Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Laundry benchtop Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Common bath Spa done and shower at 1200x1200 looks good size Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ a But the problem is regarding master ensuite BIR wherein we missed to check the height of shelf and it is glued to the plaster - so a problem here how to move it Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Then I saw this - the downlights supposed to go inside the cabinet but the electricians put it this way Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey PEast, is this correct for under cabinet lighting? We have asked for the same but this is absolutely not what we asked for. I thought that they would be recessed into the cabinets? We asked for the same as well, but can't find any reference to it being recessed anywhere on my plans or contract. Will need to confirm with my CSA. It looks ridiculous - better have a look. follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 472Aug 19, 2018 7:57 am pEast Ezza78 pEast So had a visit today and met SS regarding frame completion date - he showed the photos taken on 21/05/18 of work done. Have been told that PCI May be around 27:05/28 and can expect handover a week after Carpet is in Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Laundry benchtop Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Common bath Spa done and shower at 1200x1200 looks good size Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ a But the problem is regarding master ensuite BIR wherein we missed to check the height of shelf and it is glued to the plaster - so a problem here how to move it Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Then I saw this - the downlights supposed to go inside the cabinet but the electricians put it this way Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey PEast, is this correct for under cabinet lighting? We have asked for the same but this is absolutely not what we asked for. I thought that they would be recessed into the cabinets? Ezza it will be corrected - I showed to my SS my contract showing false bottom in cabinet charged around 170 and also electrical drawing showing the lights r in the centre of cabinets. Will be changed now and put into cabinets PEast, I’m worried because my drawing doesn’t show a false bottom but we were told would need it for these lights at colours. Have you got photo of your drawings? Our cabinets already made and get fitted tomorrow, I’m worried! Re: Building Arden homes Votivo 37 in South East 473Aug 19, 2018 1:10 pm _daz_ Ezza78 pEast So had a visit today and met SS regarding frame completion date - he showed the photos taken on 21/05/18 of work done. Have been told that PCI May be around 27:05/28 and can expect handover a week after Carpet is in Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Laundry benchtop Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Common bath Spa done and shower at 1200x1200 looks good size Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ a But the problem is regarding master ensuite BIR wherein we missed to check the height of shelf and it is glued to the plaster - so a problem here how to move it Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Then I saw this - the downlights supposed to go inside the cabinet but the electricians put it this way Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey PEast, is this correct for under cabinet lighting? We have asked for the same but this is absolutely not what we asked for. I thought that they would be recessed into the cabinets? We asked for the same as well, but can't find any reference to it being recessed anywhere on my plans or contract. Will need to confirm with my CSA. Let me know Daz as I’m in same boat as you except our cabinets go in Tuesday Re: Building Arden homes Votivo 37 in South East 474Aug 19, 2018 2:29 pm Ezza The V shown is the place for under cabinets. They still have to put false shelf for the cabinets. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 475Aug 19, 2018 8:38 pm And then I saw this - can’t underdtand why smoke detector is not white. If I have chosen white downlights then this turns out yellow - don’t remember being asked it’s colour Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 476Aug 19, 2018 8:39 pm It's a cover, it'll be removed. Re: Building Arden homes Votivo 37 in South East 477Aug 19, 2018 8:41 pm Re: Building Arden homes Votivo 37 in South East 479Aug 19, 2018 8:45 pm Ezza78 blackcat20 It's a cover, it'll be removed. Cover for smoke detector or for the downlight under the cabinetry? Re: Building Arden homes Votivo 37 in South East 480Aug 19, 2018 9:03 pm follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Keen to hear from people in the area who have got KDRB done on whom they got the build from? Looking for recommendations. Thanks 0 21115 May I ask why you chose not to use GJ Gardiner? I'm actually meeting with one of the sales guys tomorrow for an appointment. Definitely not signing anything yet… 3 13259 Adam Baines Grad Cert Bldg Surv / Grad Dip Bldg Surv / MSAAPA Accredited Building Professional APB20210035 Builders Lic 183023 Pest Control Lic 84868 Ph 0412202336 PO… 3 46836 |
