Browse Forums Building A New House 1 Jun 29, 2017 6:12 pm Re: Please check our brick work. 2Jun 30, 2017 3:58 pm I had a quick look at tolerances - for vertical it can be up to 15mm which your top photo is and for horizontal it can be up to 13mm which yours is larger. However I was only quickly looking and might be wrong. This was for nsw, all states are different. As for a fix, I guess they would have to pull down and redo it all. I would stand back and see if it's really noticeable to the eye or if you can live with it. If not then speak to your builder and make sure to reference building standards and tolerances. ~Shellby~ GJ Bridgewater 203 11/3/2016 - Site Work Started 29/9/2016 - Handover 142 Work Days 6 Work Days Over https://forum.homeone.com.au/viewtopic.php?f=31&t=80174 DIY, Home Maintenance & Repair could be the footing or being hard up against the other wall with no expansion joint or both. You could try again with brick mesh and use some sticky back foam against the… 1 1089 i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98681 Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3502 |
