Browse Forums Building A New House 1 Dec 01, 2006 10:45 pm Hello all,
In regards to soil tests being performed to determine foundations etc, how many cores are drilled, to what depth, and does the requirement alter from state to state or council to council? Does one single core in the middle of the block to a depth of approx 1300mm seem enough, and is some of the core taken away for analysis or graded by feel on location etc and by experience? Thanks all. Re: Soil tests ?? 2Dec 02, 2006 5:30 pm AS2870, the australian standard for residential slabs and footings construction nominates a minimum of one bore hole to a minimum of 1500 unless rock is encountered or in the opinion of the classifier further drilling is unnecessary.
It is common for 3 bore holes to be drilled but this is only a requirement in areas subject to a lot of movement. Soil test reports will state blah blah blah as a result of blah blah blah & soil type blah blah we recommend a footing type blah blah. And very often it will state in the report - "If differing soil profiles are encountered during excavations contact 'whoever it is' before proceeding. All building work must stop until further advice is obtained." If you are having doubts as to the quality of the test ask the soil testing firm and document everything said. The soil test is the crux of the structural soundness of your home. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Soil tests ?? 4Dec 02, 2006 6:10 pm Thankyou. Hope it helped. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Soil Test 5Jan 14, 2007 8:37 am Hi,
I got a soil test done through one builder with whom I am still having discussions re my home project. In the mean time I found a design from another builder, which was almost $50K cheaper than the earlier builder. The new builder is asking me to shell out $1K as deposit to do the soil test and drawings (I paid $500 to the earlier builder to get this done for me). When I told the second builder that I have a soil test report and do not require a new one to be done, he responded that they would have to do another test done from their panel of testers (which does not include the company which did the first test). Is this normal and acceptable? Or I am being taken for a ride? Thanks Raj I am not sure whether Perth has its own way of doing things in regards to this. Most of Perth has class A (sandy soil), except for some areas near rivers or hills. 2 13098 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37142 DIY, Home Maintenance & Repair I'm in WA and our sandy soils make drainage a bit easier but this is what I'd be doing. Dig down to your footings and let the wall dry out. Clean it all well by brushing… 1 5193 |
