Browse Forums Building A New House 1 Jun 26, 2017 2:04 pm We are in the planning stage for building a Duplex with Mastertons and they have included a provisioning allowance of $30K for a storm water solution due to the fact the land slope very slightly to the rear. Does this sounds accurate to you? We are in Sydney , Shire region, Re: Storm Water Solution 2Jun 26, 2017 8:01 pm A have seen similar prices for blocks around Sydney. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Storm Water Solution 3Jun 27, 2017 1:02 pm pommie have included a provisioning allowance of $30K for a storm water solution due to the fact the land slope very slightly to the rear. Why don't they do a much cheaper detention system? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Storm Water Solution 4Jun 27, 2017 2:11 pm SaveH2O pommie have included a provisioning allowance of $30K for a storm water solution due to the fact the land slope very slightly to the rear. Why don't they do a much cheaper detention system? That's i guess what im trying to understand. Im not sure how this charged storm water solution operates or what it should cost but 30K did seem a lot to me. Re: Storm Water Solution 5Jun 27, 2017 4:26 pm There are a range of issues with stormwater which can all add to the cost.
To understand a bit more check out this link; http://anewhouse.com.au/2014/08/stormwa ... rge-point/ Without knowing anything about the block and the regulations for your area its hard to give an answer but I have seen posts on this site from people in Sydney that have had stormwater costs in excess of $40,000! The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Storm Water Solution 6Jun 27, 2017 4:38 pm Thanks for your response. All i know is that there is no natural fall to the street. There is no chance of an easement. The solution we be a charged water solution, i believe they mentioned having a 10,000l tank under each driveway. Anyway, it sounds like anything is possible in this instance. Cheers Re: Storm Water Solution 7Jun 27, 2017 6:49 pm Having the roof drainage plumbed to a detention system wouldn't be a problem with the "very slight slope" as described but the surface drainage is another matter. Most often the two are combined as an expensive pumped system and this requires two large pumps operating in duplicate to prevent one pump frequently cycling. The problem with pumped systems of course is that pumps require power but continuity of supply cannot be guaranteed during a big storm. I am a strong believer that there should be ground water recharge points installed on properties for a number of environmental reasons but most councils are not forward thinking. Having a roof drainage detention system and excess surface water diverted to a groundwater recharge point would have both environmental and cost benefits in your case. Perhaps you could investigate this possibility for your situation. You need to keep in mind that the BCA is promoted as a performance based document, something that bureaucrats often overlook in their zeal to look for applicable regulations. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7793 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6835 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 9531 |
