Browse Forums Building A New House Re: Better Built Homes BBH 3Jun 26, 2017 2:24 pm Thank you deepugjacob, I appreciate your help here! The speed at which BBH is working our documentation starting from Tender is unbelievable slow. I am afraid it does not end up being a good builder turned nightmare due to more jobs accepted than what they can chew. Re: Better Built Homes BBH 4Jun 26, 2017 2:44 pm indu.singh0602 Thank you deepugjacob, I appreciate your help here! The speed at which BBH is working our documentation starting from Tender is unbelievable slow. I am afraid it does not end up being a good builder turned nightmare due to more jobs accepted than what they can chew. Yes Indu That's the case with most builders these days. We have to be patient I guess Re: Better Built Homes BBH 5Jun 26, 2017 2:54 pm Unfortunately. We are also building in Cherrybrook and good to know another there! Re: Better Built Homes BBH 6Jun 26, 2017 3:42 pm indu.singh0602 Unfortunately. We are also building in Cherrybrook and good to know another there! Wow!!! So we are going to be neighbors..... there will be lots of surprises. Take it as it comes and enjoy the ride Re: Better Built Homes BBH 7Jun 26, 2017 7:27 pm We are also building with BBH and had to submit an in depth landscape plan. BBH said their indicative plan wouldn't be acceptable to council because we are on a difficult block (flood affected) and will be having a pool. Re: Better Built Homes BBH 8Jun 27, 2017 8:17 am mathewfrost We are also building with BBH and had to submit an in depth landscape plan. BBH said their indicative plan wouldn't be acceptable to council because we are on a difficult block (flood affected) and will be having a pool. Re: Better Built Homes BBH 9Jun 27, 2017 9:19 am Our was a bit longer 5-6 weeks, because we had to get some extra hydraulic reports, bushfire etc I know Basix can take a couple of weeks, so I think 4 weeks is pretty standard. Re: Better Built Homes BBH 10Jun 27, 2017 4:33 pm Update on our issue: We have received a call from the management in BBH and they did acknowledge the problems and have promised us that, it be council ready by the end of next week. Fingers crossed and will keep it updated here! I would say there is no perfect builder in the market at the moment, and as long as we keep moving without compromising much! Honestly so far BBH has been much better than rest of the builders (based on personal experience and that of our friends). I just hope that this one is just a small hitch in a larger scheme of things. Hoping the best!! brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7579 Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra… 2 1013 I haven’t. But have a Lowe Design home. Not only did I find Matt Lowe patronising and a bully, but the home is NOT TO CODE. I have water coming through the bricks… 1 14397 |
